Only goes down to 34 degrees F [RESOLVED]
I am running WD 10.37Qb87 on Win 7 x64 Quad core 2.5GHz 4GB RAM with a OS WMR 968 using the extra sensor 1 as my main temperature.
Hello, the graph display and Temperature on the WD screen will only ever go down to 34.0 F, the graph shows a straight line until the temperature goes above that in the morning. Going to view the extra sensors page shows the correct temperature, as does the display on the WMR 968 itself. This has been happening for about a week or two now.
Adam
check the minimum temperature limit for the outdoor temperature in the control panel, offsets…limits setup
Thank you, guess I set that six months ago and forgot about it. :oops:
