Nueva consola David
Se está viendo la posibilidad de poder incorporar los datos de la consola David en el Water display, Como lo están haciendo los compañeros de Meteoclimatic
If David = Davis, and Water display = Weather Display, I don’t think you can connect the new 6313 console directly to a PC running WD. I think you can get the data from weatherlink.com?
I hope that someone that knows about Davis kit will join in. . . :confused:
This is what he is saying, and yes BOS is correct David=davis and Water= WD
