Hello.
How do I change the notification pop up for high winds in the PWS Dashboard?
Sincerely
Mark
Hello.
Sincerely
Mark
There are multiple notifications possible.
If you want to change the colors a.s.o. for all notifications
→ CSS is in PWS_index2.php lines 235 → 267
The code is generated by the PWS_notifications.php script current version: 01|2021-04-21|
The time the notification(s) are shown is set in line 40 of that script
There are test-settings to force the notifications to “show themselves” at lines 33-36 of that script
Thank you. If I want a wind warning already at 12 m/s, how do I change that criterion?
The easiest way is and was to change line 78 from
if ($spd_kts >= $notifyWindGust )
to
if ($spd_kts >= 23 )
At least if i calculated correctly the 12 m/s into 23 knots.
$spd_kts = $weather['wind_speed'] * $toKnots;
The notification blocks use wind_speednot wind_gust
If you want to use gust, change line 77 from
$spd_kts = $weather[‘wind_speed’] * $toKnots;
to
$spd_kts = $weather[‘wind_gust_speed’] * $toKnots;
Now it works.
Can you set criteria for when it should use warning $ntfc_strng_l
Two warnings have been issued for strong winds. When will the second high wind warning be activated?
Hi Mark, 79
Your website Fredericia Home Weather Station (weatherlink version)
The script http://www.vejret-balslev.dk/pwsWD/PWS_notifications.php?sce=view
It seems you changed the wrong line, my post says line 78 from
to
You changed line 79
# ----------------------------------------- WIND
$spd_kts = $weather['wind_gust_speed'] * $toKnots;
{ if ($spd_kts > 23) { $txt1 = $ntfc_gale_l ;}
else { $txt1 = $ntfc_strng_l;}
$arr[] = $txt1 .' <b class="yellow">'.$weather['wind_gust_speed'].' '.$weather['wind_units'].'</b>';}
Line 78 sets the message for the low-level wind_gust_speed
Line 79 sets the message for the higherlevel wind_gust_speed
if ($spd_kts >= 23
{ if ($spd_kts > 34) { $txt1 = $ntfc_gale_l ;}
Thank you very much. then I got it fixed
Can you add more notifications yourself, or is it locked to the 3 - lightning, UV and wind?
Hi Mark,
It is open code. You can add other notifications yourself.
I included those three (four) as they were in the original weather34 for WeatherDisplay version.
If you add others please post your script so others can benefit.
Thank you.
Sincerely
Mark
Just a question on this.
what file does the following pick up from is it PWS_livedata.php?
$ntfc_uv_l = lang(‘High UV-Level’).‘
’.lang(‘Reduce Sun Exposure’);
$ntfc_heat_l = lang(‘Heat Index Caution’).‘
’.lang(‘Heat Exhaustion’);
$ntfc_gale_l = lang(‘Gale Force Wind Gusts’);
$ntfc_strng_l = lang(‘Strong Wind Gusts Caution!’);
Hi swright1957,
All scripts use the $weather array.
That data is loaded by calling PWS_livedata.php which loads, using multiple scripts, all current+high_low weather values in the units choosen by the visitor.
You can check what data for your setup is in the $weather-array
→ PWS_module_test.php
----> Second line right most button “Live data values”
In the notifications script there are 4 messages possible
For UV there are two possible values
For temperature the current heat-index is used
For wind-warning the wind-speed is used as not all stations / weather-programs supply a correct wind-gust
For lightning the weather-station lighting sensor is used.
If if there is a Boltek lightning-sensor the uploaded boltek data is loaded as those values are not in the $weather array.
One can add notifications for any other exceptional value with the data in the $weather array.
Thanks Wim for that info
Silly question:
Where do you activate the notifications?
They automatically show up when an event is triggered in the PWS Dashboard
It never appeared to me. Thank you
