Hello,
I have V 10.37s149, and since JUL/12 I am not receiving new data from NETATMO. User and pass are correct on Weather Display, I see that the info on the NETATMO website is ok and updating. But WeatherDisplay is not retrieving the data.
Is there a problem?
About a week ago or so, WD stopped working with the Netatmo weather station. I had to create a separate script to download data. I see that this has also been reported elsewhere, and I suspect that this might have something to do with the access token and the refresh token.
I think you will have to e-mail Brian about this.
EDIT: Latest version of WD (15 July) has “Fix for netatmo support after major API change”
Hi, I have the same problem with version 10.37s149. Did you find a solution to the problem?
Have you downloaded the latest version of WD build 149 since15 July?
EDIT: still not updating. The netatmo connectapp terminates after a few minutes.
As far as i can see there is no newer version than 10.37s149. But i found a zip-file from 25. July. I have now tried to unpack them and I am trying again
Since my computer is restarting every night and is running unattended I hope the Netatmo logon app wil start automatically and log on to Netatmo. Testing…
Hi Reffo.
Would you care sharing the script you made?
Spiraliz.
Have you contacted Brian directly?
Hi.
No, I’m sorry I am a nube im this forum. How do I contact him?
Email Brian at [email protected]
This problem is now solved in the Weather Display install file v10.37S Build 149, Version on 1 August 2023 - 21:39:43.
Thanks to Brian
For me the problem came up again after a Windows update on Dec. 5 …
I am running 10.37S149 on Windows11 and since the update WD isn’t connecting to my Netatmno anymore. The Netatmo itelf is working fine as I can tell from Netatmo’s website and from Wetternetzwerk Pro, but connecting WD to it does not work anymore. All I get is an error (“invalid grant”).
Any suggestions?
What version of build 149? If you check the WD site there have been a couple of Netatmo changes recently.
Guess it’s the version of October 25th.
Maybe best to contact Brian direct?
