no, if I do that it’s an error in JSON as above
what is modified date/time on the latest version of WD cronwdmqtt.exe version that is not working for you? (note you can use the older version of that program with the latest version of WD)
I will search for that
For me: why is it working in v115 and not vers above :roll:
edit:
I found this quote from Renatohtpc in ‘added MQTT support’ in this thread:
http://discourse.weather-watch.com/t/66430:
[quote]For this to be possible, I had to:
- Strip the “Client ID” from the message, since its presence would result in an incorrect JSON structure]/quote]
