27th February 2024 10.37S Build 151 .zip update: Fix for wdxmlwarning.exe (new API) (this time!)
Works will but when there is “NO CURRENT ADVISORIES” my registry does not clear and the last advisory stays.
I read somewhere to manually clear it with regedit, ok that works, but it should work automatically.
What am i missing?
Try a later update from the download page:
I have the same issue with the Watches/warnings not clearing.
I am using the %NOAAEvent% tag, it does not clear but will update if watch or warning changes.
Is there another tag I should be using ?
Windgust (Amateur radio - K1DED)
Sorry, I really don’t know. . . I just remembered seeing that WD updates after 9 March should sort the WD alert problem.
tried the latest version with no success.
I’m the same as windgust post “it does not clear but will update if watch or warning changes”
Brian fixed it with-
4th April 2024 10.37S Build 151 .zip update: Another update to wdxmlwarning.exe
