NOAA warning
I am trying to get my NOAA warnings working on my site and cannot seem to open the NOAA Warning icon in the Publications portion of the Control Panel. All the others open but not NOAA. I was on build 67 and just tried build 69 with same result. I looked in the ini files to see if there was something that could be configured there but found nothing. i think that this area is what drives the testtags.txt/testtags.php? My site shows no warnings but if I put the path with rss-advisory.php (http://rockspringsridge.net/weather/rss-advisory.php) there are obviously warning today
Ideas?
has not been ported to the Mac version at this stage yet
Ahh, OK, thanks. At least I can stop fighting with it thinking I was doing something wrong. I’ll find another way I guess
It can be used with the ajax/php saratoga template version…
Thanks Dan, I went the Carter Lakes template route but I might play around with a new design. For now I put the advisories in an iFrame until I can spend more time on it. There has got to be a way to populate the Carter Lakes the way it was designed but I can’t seem to figure it out
I will be able to port the wdnoaawarningxml.exe program over to the Mac now that its using the ATOM format and has been compiled with the new compiler
is anyone interested in having that program running?
(will enable the custom tags to be populated etc)
