NOAA detailed climate report
I did a detailed climate report for each month of this year, then another one for the whole year.
I set the threshold for days with temp below -18 C and days above +25 C, but whwn I add the days from each month, it doesn t reflect the days from the beginning of the year.
Could it be because some data are missing from my month stamp log.txt files?
Thanks Brian.
I run wd1037fb14
the .txt logfiles are not used, only the .dat files
are you saying that if you add up each month, that is not the same as the total reported by year to date?
Yes Brian.
it should do
.zip and email me each months data file for the year so far
