After weeks of research, tens of posts red on different forums, I finaly found how to generate these
reports with several year of data imported from VWS.
PROBLEM: This seems to be only done manually…!
It takes between the two files about 7-9 minutes by month to be performed. WD also often time jams
during the process.
Is there a possibility to generate all the reports automaticaly…? Even if it take several hours to complete…!
VWS data files are imported, converted ok. (75 months, one at a time… :?)
Now I want generate the dailynoaa…htm, thismonth2015.htm files to upload to the server.
I am just wondering if there is an automatic command to do the generation of xxx.htm files
or if I have to generate both type of reports manulay month by month.
Should that be the case, I would suggest that improvement for a future version of WD.
Lots of time lost in that case.
