No more upload data
Good morning,
Since 25/9/22 at 2:59 AM, no more data is uploaded via meteobridge to the website: Oost-vlaanderen Home Weather Station (MB_rt version)
With the upload status of the meteobridge also the error message of the ftp upload: Requested action not taken. File unavailable.
I have also attached the 2 print screens of the notifications.
Can someone help me with this please.
Luc
Question 1: What changed at 2022-09-26 09:55:36 and / or at 22/09/2022 02:59:01
Checking the file https://www.meteoassenede.be/pwsWD12/PWS_listfile.php?file=demodata/realtime.txt
The file itself has an upload date of yesterday but the contents is from 4 days earlier
Also the graph files are missing the 25/09 line. Smething went wrong that day or at 22/09. See the duplicate and missing data for the last days.
2022-09-23 23:59:05,8,7.3,6.9,5.4,1.4,13,13,0,1023.7,1012.4,0,0,
2022-09-24 23:59:05,8,8,6.9,6.9,0,0,0,0,1023.7,1023.7,0,0,
2022-09-26 23:59:05,8,8,6.9,6.9,0,0,0,0,1023.7,1023.7,0,0,
ToDo 1:
Please use your FTP program on your PC/Mac to check the file / folder settings for demodata/ and demodata/realtime.txt
Post the settings as in attached screenshot.
ToDo 2:
In your Meteobridge add another FTP upload of the same template file towards another folder f.i. jsondata/realtime.txt
That way we can see two things:
  1. If FTP upload is possible ==> if so, it is not an FTP problem at the Meteobridge
  2. If the uploaded file contents are recent, all OK or from 22/09/202202:59:01
    => if they are from 22/09/202202:59:01 the specified template file (is input for your Meteobridge) is not correct.
    ToDo3:
    Make s screenshot of the upload settings for your realtime.txt upload. We can then check the realtime.txt template file.
P.S.
As far as i know one FTP error (the latest FTP error) is shown. There could be more.
Other MB files => FTP uploading stopped also: weather28/uploadMB/tagsMB.txt - dated: 23-09-2022 10:20
Check the MB-error-log
check the FTP password
Restart MB
Is FTP still allowed by your provider?
For test switch of the realtime.txt upload: MB->services->event->dropdown
Check after 1 hour if there are other FTP errors shown on the live data → upload status tab.
2022-08-31 23:59:05,25,15.4,15.7,13,0,41.8,30.6,761,1021.5,1019,0,2.7,
2022-09-01 23:59:05,26.1,14.8,14.6,10.3,0,27.4,19.4,745,1019.9,1016.2,0,2.8,
2022-09-02 23:59:05,27.9,12.6,15.9,9.3,0,25.9,17.6,766,1016.1,1009.1,0,2.9,
2022-09-03 23:59:05,27.3,16.3,18.2,11,0,17.6,13,831,1012.3,1008.6,0,2.9,
2022-09-04 23:59:05,27.7,15,19.1,12.7,0,25.9,19.4,758,1017.4,1012.2,0,2.9,
2022-09-05 23:59:05,29.6,17.4,18.1,12.5,10.4,27.4,16.2,649,1018.2,1014.8,0,2.4,
2022-09-06 23:59:05,28,15.4,19,14.4,25,50,22.7,731,1015.2,1011.1,0,2.8,
2022-09-07 23:59:05,24,15.4,17.4,14.9,2.8,27.4,14.4,682,1012.7,1009,0,2.7,
2022-09-08 23:59:05,21.4,15.4,16.8,13.8,14.4,25.9,19.4,837,1009,1006.2,0,2.4,
2022-09-09 23:59:05,18.1,14.6,17.1,13.3,35.4,38.5,25.9,664,1008.4,1003.7,0,1.8,
2022-09-10 23:59:05,19.7,14.7,18.3,14.2,31.6,30.6,19.4,925,1016.7,1008.1,0,2.3,
2022-09-11 23:59:05,23.3,11.8,18.7,11.5,0.2,16.2,9.7,828,1019.4,1016.6,0,2.4,
2022-09-12 23:59:05,26.3,12.6,17.5,12,0,22.7,16.2,675,1016.6,1010,0,2.4,
2022-09-13 23:59:05,23.7,17.1,20,15.1,1,19.4,16.2,679,1010.2,1008.2,0,2.8,
2022-09-14 23:59:05,17,12,15.4,11.5,33,19.4,17.6,165,1008.1,1004.3,0,0.5,
2022-09-15 23:59:05,19.2,11.6,15.6,10,0,25.9,20.9,814,1012.1,1006.9,0,2.4,
2022-09-16 23:59:05,14.8,10.1,12.2,8.8,31.8,37.1,19.4,780,1015.2,1011.5,0,2,
2022-09-17 23:59:05,14.8,9.7,12.5,8.1,24,41.8,30.6,696,1018.6,1014.9,0,2,
2022-09-18 23:59:05,16.9,9.9,11.7,8.3,2.8,38.5,27.4,800,1018.4,1016.2,0,2.2,
2022-09-19 23:59:05,17.4,8.6,12.3,7.4,0.2,33.8,22.7,833,1023.3,1018.5,0,2.1,
2022-09-20 23:59:05,16.7,7.9,13.3,7.3,0.4,20.9,7.9,830,1025.8,1022.6,0,1.9,
2022-09-21 23:59:05,17.8,6.7,12.6,6.1,0,17.6,13,721,1026.5,1024.3,0,2,
2022-09-22 23:59:05,9.2,8,7.5,6.9,0,0,0,0,1024.4,1023.7,0,0,
I do not understand your message with only the red data lines for the grpahs.
The last lines were are already in my post, signalling problem started at September 22.
=== There is no problem with the PWS_Dashboard.
=== There is some problem but it is inside your Meteobridge. (90%) or website provider (10%)
If it is simple, maybe we can find it here.
Otherwise post your question about the FTP-error on the MB forum.
Important: All other messages on your screenshot of the “Upload status” tab do not use FTP, they use HTTP upload.
And they 'upload" into totally different servers.
If there are no other FTP uploads to your own website:
=> First check your FTP settings in your Meteobridge using your PC/Mac
=> Make another FTP upload of some test file to your webserver.
==>Try to upload it in the same folder.
If other FTP uploads to your own website work OK: As I asked in my previous answer:
=== Hands-on help
If you are not that proficient with MB, sent a message(or an email) with the remote support link of your meteobridge and your (temporary) password.
Then i can take a look.
P.S. If you want to switch to Duth please use HWA forum for that.
Multiple answers can be found on the internet:
Another weather-program using FTP upload runs into the same error
http://discourse.weather-watch.com/t/70699
Seems the provider change the folder structure for uploads.
Solution was found when first testing manually upload.
Also http://discourse.weather-watch.com/p/563791
Same problem on a Belgian site
FTP an SFTP upload use different start-folders.
https://bobcares.com/blog/ftp-550-no-such-file-or-directory/
  1. Incorrect path
    Usually, “FTP 550 no such file or directory” error happens when the customers try to upload files from the wrong directory.
    For example, when the file is present in the folder /home/user/abc.html, an attempt to upload from the path /home will cause this error.
    This error also happens when customer uses the relative path in FTP.
Solved,
MeteoA sent me the login credentials of the Metebridge.
This problem was caused by the hosting-provider change which resulted in extra “folders” between the old “start ftp location” <—> root of users wersite.
All current links started with a / which now points to the old root location.
Remoing that / solved all stalled updates to the root or to folders.
