I updated WD to 10.37Q Build 57 and found that I don’t get wind direction, only speed from metar.
My station’s wind is updated from YSSY metar but since upgrade, wind direction has flatlined at 000 degrees but still gets wind speed.
I have tried restarting etc, no difference.
I did make a change where you can set to have just use the wind direction
might be that code I added
I will check
why are you needing to use a metar for wind direction?
Hi, the location of my weather station is obstructed, so it’s easier to have metar updates.
I will update a fix now
but try ticking that new wind direction only setting
Thanks. The tick box didn’t make any difference. I have put my wx station to update from wind sensor for now until fix is done.
Cheers
try that latest .zip update
