HI
have noticed this before, but seems to clear itself, but data has stopped being uploaded to my web site. worked fine after having to reinstall WD for a couple of days but now has stopped. have checked to see if web page will receive data by using another programme, and weather data is sent and loaded. any thoughts?
are you using the latest WD mac version?
(make sure you are)
try deleting the wdisplayftpreal.ini file
then go to the FTP setup in WD and make sure the FTP settings are correct and then click on OK
then go to the webfiles/web page setup, then click on OK
and that should get that ini file recreated
Brian
I always us the latest versions of WD.
followed the instructions, and at appears to be working again, will this be a permeant fix? or will in need to repeat periodicly?
