NMEA message pressure not being read
Question, I was previously using a Vaisala WXT520 with WD and everything was working properly. Well… the Vaisala suffered some damage after taking a fall. I also have a Gill Maximet with NMEA output so I decided to connect it to WD. All parameters work correctly with the exception of the pressure. I think the WD software prefers to see the pressure in mB but the Gill only allows for the pressure to be displayed in Bars. Is there a way to get this working in WD? I had this same issue with the Vaisala, but Vaisala allows you to change the units of the individual parameters within the NMEA message. Thanks!
You might have to e-mail Brian direct for an answer to this.
