Fatal error : Uncaught TypeError: array_key_exists(): Argument #2 ($array) must be of type array, null given in /home/cyupco15/public_html/PWS_livedata.php:1952 Stack trace: #0 /home/cyupco15/public_html/PWS_index2.php(30): include() #1 /home/cyupco15/public_html/index.php(38): include(‘/home/cyupco15/…’) #2 /home/cyupco15/public_html/_test.php(17): include(‘/home/cyupco15/…’) #3 {main} thrown in /home/cyupco15/public_html/PWS_livedata.php on line 1952
You selected in easyweathersetup to use weatherflow for lightning.
But the recent file of [station_id] => 67776 Town of Carstairs has this as contents:
[status_message] => SUCCESS - Either no capabilities or no recent observations
That is a new one for me.
When there is no data the it is still called SUCCESS.
Very strange log.
Who is your provider? I want to find a description of their “How-To cron-setup”.
if whc.ca (WebHostingCanada) this is how it should done
Normally a cron log shows the returned texts, this is some list of whatever.
It shows what is started but not what the result is.
Three different commands without the succes or error codes?
Those 3 lines are very different, to say the least, so how do we know which one is correct?
When testing, most providers will sent you an e-mail or put the results in a file to check
To Do:
Reread the providers documentation and/or post the URL to that documentation here
Use only one cron-setup at your provider not two or three ( “log” shows 2 crons at for 17:45:01)
Check if there is a good result (10 minutes wait) and if not adept the cron-setup.
If that not helps, quit using the “providers” cron setup and use an free cron service-provider
These two i have not heard any complaints.
Multiple others also when using Google-search, most are fine but read the discussions
For 1 cron every 5 minutes some external cron-providers provide that for free
@ALL 8 hours Time difference Hope some help is available more local to your place
Just 1 cronjob is needed for the current release of PWS-Dashboard.
Only the every 5 minute station cron.
There were two others in the first release, but they are not needed anymore.
The reason there was a few cron jobs is because I’d tried a few different options after getting different advice from the tech support at WHC hosting, I added a few to see if one of them worked.
You have probably tested to retrieve a purpleair sensor with ID 4327
The resulting data-request is stored in the status-file.
How-to-solve
Simple delete the . . /pwsWD/ _my_settings/status.arr
That file will be rebuild from scratch and within 24 hours the file will be complete again without a warning for a not used file.
./jsondata/wucom.txt is the file with the data downloaded from WU.
Messages for that file come and go but never result in a “red” warning.
It is a bit complex and translating from Dutch to English does not help either.
In the setup of PWS_Dashboard your wu data file has a max-age of 200 seconds.
And only when there is a visitor the data is retrieved every 200 seconds.
The cron-job runs every 5 minutes and will load that data if the age is more then 200 seconds.
WeatherUnderground also returns valid data every 5 minutes.
A 5 minute cron and a theoretically up-to 4:59 minute old data from WU countered with the 2 minute allowed age when there is a visitor active.
Incidentally, I ordered a purpleAir sensor from their website last week and haven’t heard back from them despite several emails and FB messages. I wonder if they are having some sort of financial issues?
