if set to show temperature, now the decimal place is shown!
as I figured out how to create the icon on the fly!
this is a great new feature I think
customise the colours under setup, advanced/misc
(so that on Vista you can set a colour different to vistaās new areo colour (dark blue)
one problem i see now,now that I have the clientviewer using this new method:
its cpu intensiveā¦
ah, ok, update, i have identified the cause of the high cpu in the clientviewerā¦uploading a new versoin now
i have this working better nowā¦faster and less cpu useā¦i did it a different wayā¦should have done it that way in the first placeā¦
build 02 .zip ready now
Am I misunderstanding all this?
Wind direction, wind speed -mph to one decimal place- and temp to one decimal place has always been shown in the tray (or for a long time)
Colour - black font on grey of taskbar
new .zip update, you can now set option to have temperature/windspeed/direction/rain alternate as what is shown on the icon in the system tray (note, you need to first have ticked to show temperature or windspeed on the system tray icon in the units setup)
Hold the phone:
i needed to first delete the newly added icon image to the listā¦otherwise the image list was getting longer and longerā¦and causing more and more CPU useā¦which would make wd unstable
so, fixed that now, build 03 http://www.weather-display.com/downloadfiles/WeatherD.zip
sorry about these teething problems!
just noticed the background colour for the icon does not work under windows2000
but it does with XP and Vista
note also i have updated the clientviewer version too
also, i actualy suspect this new method is using less cpu than before i made the change,too, which is good
Hi!
I canāt get the icon background or font colors to āstickā after shutting WD down using save/exit. I looked in wdisplay.ini, and the font size and āboldā are there ā¦but none of the color entries. :dontknow:
I just tried the alternate option. It works ā¦some of the data is chopped off though. Is that because I havenāt customized the data to display with my own tags?
Mine gets chopped as well, so that I see only the two digits to the left of the decimal point⦠I wonder⦠what will happen when the temps out here in Southern California go over 100F??
I adjusted to background color of the icon to match my tray color and when I re-start WD the change I made is gone. Itās not saving the custom color I setā¦
