New guy, man am I lost! (TE831W-2)
my QT version test is still running just fine here with my Irox station
I will add some more debug code…to see what is/what is not happening
does the clock on the WD main screen update OK?
The QT version has been sitting idle for a while and the clock has not changed in about two hours. I started it up again to watch. The clock works for about 20 seconds then freezes.
Then again, I just unplugged the weather station and stared up WD. The clock came up with the right time then after a 10 seconds or so froze. Looks like it pulls the time (at least initially) from the system and not the weather station?
I loaded WD on my vista box to see if there was an issue with my TE831W. It connected with no problem and the data looked good. Looks like a linux based issue.
I made a test with this version and my Irox, starting from scratch, I get the same result, the first reading is correct at the second reading the clock stops and sit there for hours. No error can be seen in the terminal window
Thank you for the verification Yves!
It’s good to know I’m not crazy :smiley:
for some reason you guys must not have the latest version then (because it works OK here)
uploading build 15 now
new QT version update ready now
Woot!!!
The new build you posted (10.37j build 15) is working!!! This is great. Too bad I have to head to bed (5 am comes too early for me!!!).
I’ll play with this tomorrow. Thanks much!
Great build 15 fixes the trouble. was running build 14 before.
Thanks Brian,
Yves
