New Ftpupd.exe version -> 4x faster!
Had an FTP error and had to close, can’t post attachements at present… I will write it down…
First message:
The instruction at “0x00e1f7c3” referenced memory at “0x000007b0”. The memory could not be “read”.
Cilck on OK to terminate the program
Click on CANCEL to debug the program
Next window… after Cancel…
Exception EAccessViolation in module ftpupd.exe at 00E0E7C3.
Access violation at address 00E0E7C3. Read of address 000007B0.
HTH…
Cheers
Graeme
I just downloaded the latest version and have no issues at this time and CWOP works so far.
Chuck
I believe my data is getting through despite the errors. CWOP shows growing data points on the trends. That’s a bit weird. Perhaps onbe element is missing? The full log looks ok. ok I can’t read the one for CWOP this time.
I updated 4 hours ago. No CWOP issues, but I just came back to the computer with 8 FTP crash notifications
had to head out…back now…I will make the CWOP routine done via a separate croncwop.exe
going to do that now …back soon…
I have just checked and my CWOP data has not been uploaded since I started this new FTP program 5 hours ago, so I’ve gone back to the previous version for now.
The next version about 2hrs ago did help but there is an error in the application but it does send the data…
Graeme
Ok, done that now:
http://www.weather-display.com/downloadfiles/Ftpupd.zip
working ok here now, the cwop data send, via the separate croncwop
(writes to a cwoplogsend.txt file)
(i just need to add in some checks to rotate if an error, wil do that a bit later)
Thanks Brian - I will know in 9 minutes. :slight_smile:
Graeme
Got this, only saw the FTP icon, not the other one.
list of files uploaded*
Start Time/date:1:02:05 p.m. 8/11/2008
Permanent connection selected
Checking for what else to do…
there are 1 more things to do
Aprs data sending now…
Running croncwop.exe now
Last report from CW8262 received 2 minutes 4 seconds ago
Ok data is through and no errors.
THANKS BRIAN!!
TIME FOR OTHERS TO HELP HIM OUT SOME AS THE LATEST SPEEDY FTPUPD.EXE INCURRED SOME COSTS I BELIEVE…
Graeme
NZ TK
having the cwop upload as separate is going to help anyway…as when it failed, it caused other problems :slight_smile:
I have updated the .zip and full install versions now :slight_smile:
with the much faster FTP uploads, my own weather site is now much more up to date :slight_smile:
Still have the issue with ftpupd keeping the anything weather directory info, then closing on the error to my web page upload. Think I can get around it by shifting the anything weather to a different time. Thanks for all your efforts. The separate croncwop.exe works great.
Jim
just realised that the WeatherD.zip and full installs do not have the latest Ftpupd.exe
re uploading those now
Jim, if you could .zip and email me your settings , I will see if I can duplicate the problem here
settings files sent (email will show as from jandcbro)
The only issue I’m now having, even with the above mentioned 8.95 ftpupdt.exe version, is the ftp metar download. The old http metar download method works great. But with the newer ftp metar download method, I show the following in ftplogfull.txt:
Start Time/date:11:00:18 PM 11/6/2008
orz042.txt
Connecting to FTP server.
Connected.
220 Authorized users only. All activity may be monitored and reported.
USER=****
331 Please specify the password.
PASSWORD=****
230 Login successful.
changing directory to /data/observations/metar/decoded/
CWD /data/observations/metar/decoded/
250 Directory successfully changed.
Next file FTP metar station download
Downloadding to c:\wdisplay\metar\KSLE.met
148: LocalFile already exists and Overwrite is False.
QUIT
221 Goodbye.
Disconnected.
Downloadding to c:\wdisplay\metar\KDLS.met
Connected.
USER=****
PASSWORD=****
QUIT
221 Goodbye.
Disconnected.
Downloadding to c:\wdisplay\metar\KYKM.met
Connected.
USER=****
PASSWORD=****
QUIT
221 Goodbye.
Disconnected.
Sure enough, a check of my WD metar directory showed that the .met files were not updated, I assume because of the “overwrite is false” condition?
ah, fixed that,hopefully
and the change in directory problem (the upgraded component behaves a bit different now)
new update
vers 8.96
FTP Metar download works perfect now using ftpupd.exe Vers 8.96. Hey… you even have Passive mode working with that too! Excellant ! :smiley:
Thank you ! :slight_smile:
Downloaded and installed the new ftp yesterday and all is working very well and much faster. Also downloaded 8.96 just a bit ago. But here’s the but…
It appears that it may, and I stress may, have upset both my WASP2 and StrikeLink to StrikeStarUS. Not long after I installed it both programs have been unable to connect to their network. One other user who also uses WD said she had the same problem. I asked if she updated to the new ftp yesterday also but haven’t received a reply.
I reinstalled WD to an earlier version, 37M build 11 which has ftp version 8.90 which I believe is the old ftp. It didn’t make a difference as far as StrikeStar is concerned.
So I guess my question is can the new WD ftp cause problems with other ftp programs? Also there is a .dll file with the new. Is that also new and did it replace anything?
–Dave
Thanks, Brian! Works perfectly for me now and as you say, a great deal faster!
Don’t know how you do it - you just keep making a great program better and better!!
I upgraded the FTP this morning and CWOP is working fine now…
