Netatmo under Windows
I have noticed that Netatmo under Windows doesn’t work as well as the Linux version. The temperature has not changed in a few hours and the indoor temperature is not being obtained. Just wondering have I done something wrong. I am switching to a Froggit DP1500 once it arrives
I removed and re entered the account details and now it is picking up the temperatures . I keep my password on Bitwarden so copied it over. The sooner I move away from Netatmo the better
Woke this morning and WD has only been downloading the wind data all night from Netatmo
the contents of my current rawnetatmodata test file is
{"body":{"devices":[{"_id":"70:ee:50:20:9c:ca","station_name":"Renvyle","date_setup":1521633743,"last_setup":1521633743,"type":"NAMain","last_status_store":1604138594,"module_name":"Indoor","firmware":177,"last_upgrade":1525427901,"wifi_status":35,"reachable":true,"co2_calibrating":false,"data_type":["Temperature","CO2","Humidity","Noise","Pressure"],"place":{"altitude":33,"country":"IE","timezone":"Europe\/Dublin","location":[-9.9744895,53.5961869]},"home_id":"xxxxxxx","home_name":"tully","dashboard_data":{"time_utc":1604138581,"Temperature":15.9,"CO2":1188,"Humidity":79,"Noise":75,"Pressure":986.9,"AbsolutePressure":983.1,"min_temp":14.7,"max_temp":19.5,"date_max_temp":1604102648,"date_min_temp":1604136483,"temp_trend":"up","pressure_trend":"down"},"modules":[{"_id":"05:00:00:03:bf:b2","type":"NAModule3","module_name":"Rain","last_setup":1522941340,"data_type":["Rain"],"battery_percent":94,"reachable":true,"firmware":12,"last_message":1604138592,"last_seen":1604138592,"rf_status":63,"battery_vp":5860,"dashboard_data":{"time_utc":1604138579,"Rain":0,"sum_rain_1":0,"sum_rain_24":27.9}},{"_id":"06:00:00:02:58:70","type":"NAModule2","module_name":"Wind","last_setup":1522755242,"data_type":["Wind"],"battery_percent":39,"reachable":true,"firmware":25,"last_message":1604138592,"last_seen":1604138592,"rf_status":67,"battery_vp":4754,"dashboard_data":{"time_utc":1604138579,"WindStrength":14,"WindAngle":246,"GustStrength":44,"GustAngle":278,"max_wind_str":88,"max_wind_angle":192,"date_max_wind_str":1604119040}},{"_id":"02:00:00:62:ff:78","type":"NAModule1","module_name":"Outdoor","last_setup":1597230091,"data_type":["Temperature","Humidity"],"battery_percent":92,"reachable":true,"firmware":50,"last_message":1604138592,"last_seen":1604138553,"rf_status":71,"battery_vp":5812,"dashboard_data":{"time_utc":1604138553,"Temperature":9.8,"Humidity":100,"min_temp":8.9,"max_temp":14,"date_max_temp":1604118591,"date_min_temp":1604133664,"temp_trend":"up"}}]}],"user":{"mail":"[email protected]","administrative":{"lang":"en-GB","reg_locale":"en-IE","country":"EN_US","unit":0,"windunit":0,"pressureunit":0,"feel_like_algo":0}}},"status":"ok","time_exec":0.11091089248657227,"time_server":1604138886}
My webste shows:
email me your Netatmo details (email/user and password) so that I can see what is going wrong here
Sending email now.
working oK here, latest version of WD
this is what shows under view, debug info, in WD
Outdoor temp 8.9
Extra Indoor temp
Outdoor hum 98
Extra indoor hum
Barometer 994.6
Indoor hum 72
Indoor temp 19.4
CO2 2726
noise 50
Wind direction 188
Wind speed 10
Wind gust 25
Rain 28.5}},{“_id”:“06:00:00:02:58:70”
Rain ->28.5<-
and that matches the data in the rawnetatmodata.txt file
Thanks for the help. It turned out something was wrong with the wdisplay.ini file after I moved it from Linux. So i removed it and everything works
