I have created a interface script to view JpGraph
Hi Krister
What a great script. Now I have something to play with today and maybe translate to Danish.
Henrik
thanks man!!!
Your site is inspirational :headbang:
Hi Henrik and Mario
I’m glad you like it
If you downloaded the first version you should delete the database connection info in common_en.php
I forgot to erase it :oops:
The database connection info should be entered in get_data.php, and it might mess things up if it remains in common_en.php
Krister
Hi Krister
I have been playing with your scripts - but cant get it to work.
I dont know whats wrong. I have downloaded your latest release.
Link: http://www.buskelundtoften.dk/vejret/webpages/multiwx_en.php
What can be the problem?
Henrik
Hi Henrik
Is the path to Jpgraph correct?
The default path is Jpgraph src folder is in the same folder as multiwx and webpages folder
You can change this in multigraph.php
Krister
Hi Krister
Thanks for your reply.
Yes my “src” folder is in the same folder as multiwx and webpages folder.
I have dobble checked the connection string to mysql database and everything seems correct.
Henrik
Hi again
change
include ($com_lang);
in get_data.php to
include ('common_en.php');
and see if it works
Krister
Hi Krister
Sorry - still no luck.
Henrik
Ps. my webhotel is running on a Windows 2003 server - could that be the problem?
Hi again
If you go directly to http://www.buskelundtoften.dk/vejret/multiwx/multigraph.php
you will see this: getmysql error (If it works you will see a graph).
Before it complained that it could not find the included file, so that is fixed, i don’t know why it did not work.
If you are using the original WDMYSQL table you need to change the mysql_query because it uses datetime and that field does not exist
in the original table. == getmysql error
You also have to change the arrays $db_field , $db_units and $db_fieldname so it matches your database
Krister
Hi again
Yes i use the origina wdmysql database/table
Im not sure what to change in the script.
Henrik
Hi again
In common_en.php the array $db_field should contain the field names of the database like this:
$db_field = array("" => "", 1 => "station_id", 2 => "date", 3 => "time", 4 => "average_windspeed"
and in
$db_units = array("" => "", 1 => "", 2 => "Date", 3 => "Time", 4 => "m/s"
and in $db_fieldname the fields you want in the select droplist. The key number is the same as in $db_field , the text is just for the droplist so it can be translated.
The query:
$sql = mysql_query("SELECT UNIX_TIMESTAMP(DATETIME) AS DATETIME, DATETIME, $que1 AND humidity IS NOT NULL ORDER BY DATETIME ASC") or die("getmysql error");
does not work because your database does not have DATETIME, you have to use DATE and TIME in the query , i’m not sure how to do that #-o
Krister
Hi Krister
Thank you very much for your reply.
I hope somebody can modify your excellent script to work with the original wdmysql database.
Henrik
Hi again
I have modified the script so it should work with the WDMySQL-table
(It works on my testtable on localhost with 2 hours of data) :roll:
I have not added all fields for the select droplist, but it is easy to add more in common_en.php and rename/translate them.
I have attached a zip-file with the new code
Krister
Hi Krister
Thanks for all your work.
Unfortunately I cant get it to work. I have the mysql settings in the get_data.php file.
Anything else to do?
Henrik
I have changed fonts in multigraph.php, try this new upload.
I have also included a testfile.php, try that one and see if it outputs any values if the new multigraph.php does not work
Krister
Hi Krister
Still no luck.
There is a lot of things in this link - but im not sure what is means:
http://www.buskelundtoften.dk/vejret/multiwx/testfile.php
Henrik
line 95 in multigraph.php
change
$graph->title->Pos(0.08, 0.02, "left", "top");
in
$graph->title->SetPos(0.08, 0.02, "left", "top");
for some strange reason some jpgraph-instalations don’t uderstand the “Pos”
change it to “SetPos”
Jozef
hope this helps
That did the trick.
But when I try to make different graphs - only the temperature graph from today shows up.
Thanks for all your help.
Henrik
Hi again
I have changed Pos to SetPos in the script (Thanks Jozef)
I have also changed the initial query so it will load faster.
I have added a couple of files for testing if sessions and db-query works.
Make a time and data selection and click on create graph in: multiwx_en_test.php
Check the result in the S_SESSION array, and click on the link: open testfile.php below script timer.
If sessions works the new page will be filled with values from the selections.
You can test it here http://hasslosa.se/weather/webpages/multiwx_en_test.php (there is values between 2007-11-19 and 2007-11-20)
Krister
