1. When setting up the sensor in HA configuration.yaml. Am I missing something? Config check does not like it (See in Bold below).
This was what renatohtpc had in the topic
Topic: Added MQTT support
- platform: mqtt
state_topic: “Southampton/WD/json”
unit_of_measurement: "
Note: My state topic is: “WeatherDisplay/WD/json”
2. Another is if I use in MQTTin.txt: WeatherDisplay/temp:{“temp”:“%temp%”}
My result is: {“wchill”:21.7 } °F
How do you make it to just show 21.7 °F
Thank you.
I’ve got #1 figured out. was missing value_template in configuration.yaml.
platform: mqtt
name: “WD Outside Temp”
state_topic: “WeatherDisplay/WD/json”
unit_of_measurement: “°F”
value_template: “{{ value_json.temp }}”
platform: mqtt
name: “WD Windchill”
value_template: “{{ value_json.wchill }}”
platform: mqtt
name: “WD Outside Humidity”
unit_of_measurement: “%”
value_template: “{{ value_json.hum }}”
You can add midi files also:
Example:
platform: mqtt
icon: mdi:thermometer
You can find all the HA midi’s here: Material Design Icons
Anyone know why some of the tagslist devices do not work with MQTT?
Soiltemps??
VP soil temp/moisture/extra temperature/humidity
%VPsoilmoisture%…Davis VP soil moisture
%VPsoilmoisture2%…Davis VP soil moisture, # 2 sensor
%VPsoilmoisture3%…Davis VP soil moisture, # 3 sensor
%VPsoilmoisture4%…Davis VP soil moisture, # 4 sensor
%soilmoistpercent%…Davis VP soil moisture expressed as a percentage (100% is saturated)
%VPsoiltemp%…Davis VP soil temperature #1
%VPsoiltemp2%…Davis VP soil temperature #2
%VPsoiltemp3%…Davis VP soil temperature #3
%VPsoiltemp4%…Davis VP soil temperature #4
windy2
5 February 2021 22:08
4
what version/build of WD?
10.37S123
Here is the display in HA:
http://zumbrota-weather.com/temp/Capture.PNG
Configuration.yaml:
platform: mqtt
name: “WD2 Soil Temp 1”
state_topic: “WeatherDisplay2/WD/VPsoiltemp”
platform: mqtt
name: “WD2 Soil Temp 2”
state_topic: “WeatherDisplay2/WD/VPsoiltemp2”
platform: mqtt
name: “WD2 Soil Temp 3”
state_topic: “WeatherDisplay2/WD/VPsoiltemp3”
platform: mqtt
name: “WD2 Soil Temp 4”
state_topic: “WeatherDisplay2/WD/VPsoiltemp4”
platform: mqtt
name: “WD2 Wind Direction”
state_topic: “WeatherDisplay2/WD/dirlabel”
unit_of_measurement: “”
platform: mqtt
name: “WD2 Max Windchill”
state_topic: “WeatherDisplay2/WD/maxwindchill”
platform: mqtt
name: “WD2 Windchill”
state_topic: “WeatherDisplay2/WD/windch”
platform: mqtt
state_topic: “WeatherDisplay2/WD/temp”
platform: mqtt
state_topic: “WeatherDisplay2/WD/VPuv”
platform: mqtt
name: “WD2 weatherdescription”
state_topic: “WeatherDisplay2/WD/weatherdescription”
windy2
6 February 2021 05:04
6
do you have ticked in WD that you have a soil temperature sensor?
(in the davis weather station type setup)
I have it working now. I’m by no means a MQTT expert. When you use Weatherman-Marks way, naming had to match before and after the colon. see bold. I wish the curly brackets didn’t show up when displaying in HA. I’m going to use renatohtpc’s json. No curly brackets are displayed then. Thank you Brian for your assistance.
WeatherDisplay2/VPsoiltemp :{ %VPsoiltemp % }
WeatherDisplay2/VPsoiltemp2 :{ %VPsoiltemp2 % }
WeatherDisplay2/VPsoiltemp3 :{ %VPsoiltemp3 % }
WeatherDisplay2/VPsoiltemp4 :{ %VPsoiltemp4 % }
json for soiltemps: “VPsoiltemp”:%VPsoiltemp%“,“VPsoiltemp2”:%VPsoiltemp2%”,“VPsoiltemp3”:%VPsoiltemp3%“,“VPsoiltemp4”:%VPsoiltemp4%”
