Geez, this program is sensitive. In the dials image page, I tried to move one of the temp indicators and the whole page is moving, cannot seem to be able to grab the item itself. Also, since the cloud graphic is not giving the right info because of the way my metar is reporting it, there no sense having it there, but cannot remove it from showing up. If I right mouse click on screen, select “NO” for “cloud height” it just changes it to the graph scale instead of the graphic one. One other thing, trying to get the wind chill gauge to show, it will show up, then disappears, can not get it to stay showing up on dial screen. #-o
with the weather dials, the problem there is the box outline
you need to move that out of the way, so that object behind it can then be moved
also with the dials, when they are moved, sometimes they disappear
but they are still there…just move them again (where you last saw them)
as for the cloud height, do you mean you are using the humidity from a metar?
you could move the cloud height off screen
as for the windchill, that will only show if the temperature is below 10c
I tested the cloud height show/not show
setting to no made it dissapear ok
Hi Brian, ok, so the outline box is causing this, I will give that another try. Cloud base height image, I have set the Metar and sometimes its clear here, Metar states the same, but shows 200 feet? I think in the metar report there are a cloud reading as well and its seeing this too and using it, I believe. Ok on the wind chill reading, I’ll remember that. Really, right now I have the cloud graphic on my data page, when I select NO for the cloud height, it changes the graphic to a regular scale type images, something too the temp reading display, but thought it would just go away, if I select YES again, the graphic shows up, select NO, it changes from the blue graphic back to the basic scale image…
here is my data page: Tyngsboro Weather Data and here is the current metar for my area:METAR KASH 132351Z VRB03KT 10SM CLR 24/17 A2983 RMK AO2 52004 T02380172 10288 20238 SLP104 if you look at it now, this is what it shows now that I selected [NO] to show cloud height…
OMG, this is a pita, I clicked on NO BORDER, and it keeps coming back… where is the data file for this screen so I can go in and edit it out instead of using the clickable options.
I just tested setting the border to not show
works
no PITA
which version and build of WD?
Hi, sorry, really having a hard time with it. Everytime I click no border, then working the space to re-align some items, the border shows up again and the window I’m working on resizes itself. I just lost my NW for the wind direction, cannot find it…and I added the windchill option, says its clicked YES, but not showing up until I click yes again… I’m on build 74 right now…
Relook at my page again, there is the black line thru the botton of it and I have NO selected…
what is the URL you are refering to?
you can start over with the customisation, in the setup, advanced/misc
I can not duplicate the problems here that you are having
.zip and email me your settings files I and will test with your settings
My data webpage is listed below, what settings are you looking for? and yes, I finally did that after losing a few items and couldn’t locate them and had to restart it from default to get them back. I’m still trying to get the windchill image to show up. I clicked on yes, it shows up, but then when the screen refreshes and is uploaded, it disappears again…which file (name) is it? the wd.ini file?
Look in the FAQ for the settings file Brian is requesting.
when you say windchill image, do you mean the windchill dial?
the right mouse click option to show windchill actually refers to the windchill depression (left side of the screen)
to show or not show the wind chill dial thermometer, thats the show heat/chill therm option
