Monthly Rain Total Not Carrying Over
We had a fairly dry February (by our standards) and at the end of the month, the rainfall should have carried over to the Year To Date. However, it’s still showing February’s rainfall in the current month, which is March. Haven’t seen it do this before.
Showing 149.3mm, should only be showing 21.2mm (according to the Graphs section) while the rest should be added to the 499.8mm for YTD.
Hope this is fixable.
G
knowing your weather station type helps a lot (and what version/build of WD)
I ask that because you might have set to use the console rain total
in which case, check if that has cleared the month rain total
or, Q, was WD running at the time of month change over
Running version 10.37S138
Station is a Tempest Weatherflow.
As far as I know, everything was running okay at the change of month, but now that I look at the WeatherDisplay main screen, it’s showing the wrong month-to-date info as well. How do I correct this without messing everything up?
G
you can set the needed monthly rain total under control panel, offsets and initial rain
Fixed, thank you.
It had also managed to change the date format, no idea what it’s been doing lately… Found the setting and changed it back to dd/mm/yy
G
