Thank you as always Wim.
Another slight problem I have is that none of the graphs seem to work for 30 days and 360 days. What is the file that is obviously missing for this information?
AFAICS the is data there for the last two days.
Probably you did not choose to use WU for the graphs?
easyweather → tab data → question
The data to use for the graphs
- - >The graph-script should use my WU-station-data to generate the graphs
- - > **I do not want to use WU, save my weather-data for a **subset** of the graphs**
The cron-job will generate the data for the graphs during each day and also add 1 line to the month and year files.
So it seems you have this dashboard active for the last two days.
