MISOL HP2550 works with weather display
recieve today this weather station, its like a HP2551BU ecowit, but cant make working, sorry my english, i am a registered from weather display.
Those 2551 consoles do not work directly with WeatherDisplay or other weather-programs.
The solution is to use a GW1000 which has an API which WeatherDisplay (and the other weather-programs) understand.
Make sure that you order an GW1000 with the same frequency as used by your MISOL (often it is 433Mhz)
The GW1000 is a smal device, it act as a console without the glass-part.
But it has that extra API so that is can be used with multiple weather-programs, all at the same time.
i cant believe, my old froggit wh4000 works, amd this one, wifi, usb does not working #-o, thanks
