Min Max custom tags for extra sensors
I can’t find any daily High Low temperature custom tags for the LabJack extra sensors. There appear to be High Low Temperatures for all of the other extra sensors.
If they don’t exist, then would it be possible to add them into a future release?
what I will do is hook in the labjack readings to the dallas 1 wire max/min readings (and you can use the dallas 1 wire custom tags)
That would be brilliant, many thanks
download new 10.20i zip in about 1 hour from now and this should be working
I’ve downloaded the latest version and it appears to be partialy working.
My labjack sensors are sensors 4 and 5. WD appears to have picked up only the max from sensor 4 and loaded it into dallas sensor 1.
Having said that. I think it’s brilliant that you can take on board a request like this and change the software so quickly.
Here is a sample from the custom tags in the XML file
20.2
21.0
7.0
38.4
12.5
-100.0
-100.0
-100.0
20.2
21.0
7.0
38.4
12.5
-100.0
-100.0
20.2
20.4
19.1
21.0
21.0
9.5
7.0
20.9
6.5
48
57
-100.0
100.0
100.0
100.0
100.0
100.0
100.0
100.0
38.4
-100.0
-100.0
-100.0
-100.0
-100.0
-100.0
-100.0
oops
i missed changing a few lines of code
uploading a new 10.20i zip now
Thanks Brian, now working OK
