Hi all and a nice new year! Currentsky and Metar LIPE airport were working fine until jan.2024. As from that date no METAR neither AERIS data ara available in PWS-Dashboard current sky and METAR airport.
Case 1 - USING AERIS API KEY
Settings of PWS dashboard for Sky Conditions
Aeris API Access ID LNO0hnoRSmx********
Aeris API Secret Key lrNL3FP0lrCDGBK46SvH4zw**************
Results:
Currentsky: OFFLINE
One hour forecast = OK
LIPE airport data : OFFLINE
Case 2 - USING METAR ( CHECKWX ) API KEY
Settings of PWS dashboard for Sky Conditions METAR
CheckWX Metar API KEY www.checkwxapi.com: cfa4553ad0a2ae*********
Results:
Currentsky = OK ,
One hour forecast OFFLINE,
LIPE airport data OFFLINE
Test of ccn_ccb_darksky_block.php
Warning : Undefined variable $cond in /membri/michelinostreet/ccn_darksky_block.php on line 71
Warning: Trying to access array offset on value of type null in /membri/michelinostreet/ccn_darksky_block.php on line 71
Warning: Undefined variable $cond in /membri/michelinostreet/ccn_darksky_block.php on line 72
Warning: Trying to access array offset on value of type null in /membri/michelinostreet/ccn_darksky_block.php on line 72
Warning: Undefined variable $cond in /membri/michelinostreet/ccn_darksky_block.php on line 73
Warning: Trying to access array offset on value of type null in /membri/michelinostreet/ccn_darksky_block.php on line 73
Warning: Undefined variable $darksky_used_temp in /membri/michelinostreet/ccn_darksky_block.php on line 74
Deprecated: str_replace(): Passing null to parameter #3 ($subject) of type array|string is deprecated in /membri/michelinostreet/PWS_shared.php on line 80
Deprecated: strtolower(): Passing null to parameter #1 ($string) of type string is deprecated in /membri/michelinostreet/PWS_shared.php on line 81
Warning: Undefined variable $darksky_used_temp in /membri/michelinostreet/ccn_darksky_block.php on line 75
Warning: Undefined variable $cond in /membri/michelinostreet/ccn_darksky_block.php on line 77
Warning: Trying to access array offset on value of type null in /membri/michelinostreet/ccn_darksky_block.php on line 77
Warning: Undefined variable $darksky_used_temp in /membri/michelinostreet/ccn_darksky_block.php on line 85
Warning: Undefined variable $darksky_used_temp in /membri/michelinostreet/ccn_darksky_block.php on line 86
Warning: Undefined variable $cond in /membri/michelinostreet/ccn_darksky_block.php on line 90
Warning: Trying to access array offset on value of type null in /membri/michelinostreet/ccn_darksky_block.php on line 90
Warning: Undefined variable $cond in /membri/michelinostreet/ccn_darksky_block.php on line 91
Warning: Trying to access array offset on value of type null in /membri/michelinostreet/ccn_darksky_block.php on line 91
Deprecated: strtolower(): Passing null to parameter #1 ($string) of type string is deprecated in /membri/michelinostreet/ccn_darksky_block.php on line 95
Warning: Undefined variable $cond in /membri/michelinostreet/ccn_darksky_block.php on line 102
Warning: Trying to access array offset on value of type null in /membri/michelinostreet/ccn_darksky_block.php on line 102
Warning: Undefined variable $darksky_used_wind in /membri/michelinostreet/ccn_darksky_block.php on line 102
Deprecated: str_replace(): Passing null to parameter #3 ($subject) of type array|string is deprecated in /membri/michelinostreet/PWS_shared.php on line 181
Deprecated: strtolower(): Passing null to parameter #1 ($string) of type string is deprecated in /membri/michelinostreet/PWS_shared.php on line 189
Warning: Undefined variable $cond in /membri/michelinostreet/ccn_darksky_block.php on line 103
Warning: Trying to access array offset on value of type null in /membri/michelinostreet/ccn_darksky_block.php on line 103
Warning: Undefined variable $darksky_used_wind in /membri/michelinostreet/ccn_darksky_block.php on line 103
Warning: Undefined variable $cond in /membri/michelinostreet/ccn_darksky_block.php on line 104
Warning: Trying to access array offset on value of type null in /membri/michelinostreet/ccn_darksky_block.php on line 104
09:20:00
Mist | |
One hour forecast: | |
Temperature -999°C | |
Windspeed 0 km/h | |
Rain 0% |
Call checkwx.com LIPE direct data with api key = ok
Direct call METAR LIPE
https://api.checkwx.com/metar/LIPE/decoded?x-api-key=cfa4553ad0a2aea*********
Results: ok
{“results”:1,“data”:[{“icao”:“LIPE”,“barometer”:{“hg”:29.97,“hpa”:1015.0,“kpa”:101.49,“mb”:1014.9},“clouds”:[{“code”:“CLR”,“text”:“Clear skies”}],“conditions”:[{“code”:“BR”,“text”:“Mist”}],“dewpoint”:{“celsius”:-4,“fahrenheit”:25},“elevation”:{“feet”:121.0,“meters”:37.0},“flight_category”:“IFR”,“humidity”:{“percent”:100},“observed”:“2024-01-14T08:20:00”,“station”:{“geometry”:{“coordinates”:[11.2887,44.5354],“type”:“Point”},“location”:“Bologna, Emilia-Romagna, Italy”,“name”:“Bologna Guglielmo Marconi Airport”,“type”:“Airport”},“temperature”:{“celsius”:-4,“fahrenheit”:25},“raw_text”:“LIPE 140820Z 34003KT 310V010 2000 BR NSC M04/M04 Q1015”,“visibility”:{“miles”:“1.24”,“miles_float”:1.24,“meters”:“2,000”,“meters_float”:2000.0},“wind”:{“degrees”:340,“speed_kph”:6,“speed_kts”:3,“speed_mph”:3,“speed_mps”:2}}]}
Data loaded in jsondata Metar34LIPE.txt = ok
Results:
{“results”:1,“data”:[{“icao”:“LIPE”,“barometer”:{“hg”:29.97,“hpa”:1015.0,“kpa”:101.49,“mb”:1014.9},“clouds”:[{“code”:“CLR”,“text”:“Clear skies”}],“conditions”:[{“code”:“BR”,“text”:“Mist”}],“dewpoint”:{“celsius”:-5,“fahrenheit”:23},“elevation”:{“feet”:121.0,“meters”:37.0},“flight_category”:“IFR”,“humidity”:{“percent”:93},“observed”:“2024-01-14T07:50:00”,“station”:{“geometry”:{“coordinates”:[11.2887,44.5354],“type”:“Point”},“location”:“Bologna, Emilia-Romagna, Italy”,“name”:“Bologna Guglielmo Marconi Airport”,“type”:“Airport”},“temperature”:{“celsius”:-4,“fahrenheit”:25},“raw_text”:"LIPE 140750Z 34002KT 1800 BR NSC M04/M05
Can someone indicate any other test or config I must do? Thanks a lot for help
Tested through:
https://michelinostreet.altervista.org/PWS_module_test.php
