My website has suddenly stopped updating, and it is because the ftp crashes because of something related to the METAR download.
It was previously working fine and as far as I know I have not changed any settings since it went pear shaped.
This is the error msg I get on the ftplog
list of files uploaded*
Start Time/date:20:30:10 31/08/2007
Permanent connection selected
Checking for what else to do…
there are 1 more things to do
Connecting to FTP server.
Connected.
220 Authorized users only. All activity may be monitored and reported.
USER=****
331 Please specify the password.
PASSWORD=****
230 Login successful.
changing directory to /data/observations/metar/decoded/
CWD /data/observations/metar/decoded/
250 Directory successfully changed.
Next file FTP metar station download
ERROR: I/O error 103 at time/date 20:30:12 31/08/2007 agenda item:
doftpdownmetarstation
My settings that previously worked were for http download every ten minutes (yes I know they probably only update once every 30/1hr) . I have tried to use ftp download and ftp passive download but to no avail.
If I turn the main METAR button off, the data ftp’s up to my website and everything works fine.
Any suggestions?
Jeremy
try reselcting the location for the metar downloads in the ftp/internet setup
ok thanks. tried that.
I removed select METAR and then re-added it.
did not fix anything. latest error msg:
Start Time/date:21:10:09 31/08/2007
Next file HTTP metar station download
ERROR: I/O error 103 at time/date 21:10:10 31/08/2007 agenda item:
any other ideas?
but thats not what I said to do
try reselecting the metar download location
also delete the metar files in that location as well
ok thanks that has worked.
I don’t show the summary image on my webpage. is it still possible to show the METAR image under this scenario? as currently it does not show even though i can see it loading up to my web page directory.
In the “set icon from downloaded airport metar” tab i have “show metar image on web page” selected and “produce and upload metar images”. nothing else is selected.
on “summary image setup” tab I have “update image but dont show on page” selected.
try adding the html code to show the metar image on your web page to the datahtm0.txt file
I have to go now and so cant help you any more for 36 hours or so
(weekend off)
also otherwise click on update html files in the webfiles/web page setup or restart wd
