Now that’s very strange. I saw that box and knew I shouldn’t tick that one. Must’ve, though, in trying to get METAR to stick. Just unticked it. Hopefully, the METAR is still working for the current weather.
Unfortunately, the METAR image has stopped coming through. Only current weather in text now.
you might have changed to many other things possibly
or try a restart
Other than throwing the switch and accidentally ticking that one box. A restart didn’t help. Strange thing- the METAR icon worked when I had that one box ticked- "Use this Metar to update WD’s data (if you do not have a weather station only). All the other METAR data is showing on my website as you scroll down to the bottom. A real nuisance to have a clear skies icon when it’s overcast and snowing.
Something’s not right in WD, at least here. I go into Control Panel-Summary Images & Icons-Icon/VP Forecast tab and select the Use this selected Icon instead in Manual Override and select Night Snow and then click update. The icon switches briefly in WD on my screen and then goes back to clear night skies. I go back to the same setting in Control Panel and see it’s back to default Sunny. Seems like this is one of the only ways to get the right icon without shutting off the METAR switch, but that’s not even working. 2 images posted below to show the back to default Sunny. Also, going into Input Daily Weather-Select the Main Screen Icon and choosing Night Snow…also works for a moment and then back to clear night skies.
why are you using the manual override?
you seem to be making way too many changes all at once, and setting the wrong settings too
Just an attempt to get the right weather icon. Nothing seems to be working.
Actually, I just checked my website and it
The Icon has been coming across fine now for the last day and now.
With that, I had tried one of my own icons for night snow and now longer see the original available. Where might I retrieve that one?
Found it. Reset to Default Icons was it.
One thing I do find is when selecting an icon there is no way to visibly see that it is selected. Usually, in the interface, shouldn’t it visibly show what is selected by some sort of border surrounding the selection in some way?
Strange that now the METAR icon is not working. Overcast and snow in text but showing just partly cloudy skies.
