McMahon GFS 2025030206 z Missing - Last was 2025030200 z
McMahon - Last Good GFS was ( 2025030200 z ) and Last Should Be ( 2025030206 z )
Note: this was Checked at 2025-03-02 12:06 UTC.
It is possible that the Data was running Late and may now be available.
Kindest Regards,
Tony
Guess what? The database filled up again. I’m working on getting it running again ASAP.
Some “creative” database management later and the 06z GFS data is downloading.
The forecast table had reached 137GB which was a little excessive! I wish I could find out why the regular cleanup jobs aren’t cleaning up. They always run fine when run manually but for some reason they eventually give up and then the table rapidly becomes a beast that fills the entire disk.
06z data is now available.
