McMahon GFS 2024120306 z Missing - Last was 2024120300 z
McMahon - Last Good GFS was ( 2024120300 z ) and Last Should Be ( 2024120306 z )
Note: this was Checked at 2024-12-03 12:06 UTC.
It is possible that the Data was running Late and may now be available.
Kindest Regards,
Tony
The database stopped whilst I was out ordering our Xmas turkey. I think the database is a turkey sometimes.
I’m going through the startup sequence now. Server 1 is back up and server 2 is synchronising with it. I should be able to get the GFS/ECMWF scripts running once I’ve got two servers back up.
I was just getting the database fixed when things went wacky. I eventually traced it back to a network issue which seems to have been related to Cloudflare. It’s possible that the Cloudflare issue caused the database problem in the first place but it’s difficult to be sure.
I think the network issue has been resolved now but it’s teatime (as we call it oop North - dinner time if you’re posh lol). I’ll get back to the database fix once we’ve finished eating.
The database is now in sync on two servers with the third underway now.
All databases are running properly. I had some further issues with replicated storage due to the network disconnections but those are repaired now.
The 12z GFS and ECMWF runs are processing as I type so within about 30 minutes there should be new data available.
12z data for 3rd December is now available.
