McMahon - Last Good GFS was ( 2024041512 z ) and Last Should Be ( 2024041612 z )
Note: this was Checked at 2024-04-16 19:06 UTC.
It is possible that the Data was running Late and may now be available.
Kindest Regards,
Tony
20240416 12z is now available after a successful run with the fixed code - removing FTP usage.
It took longer than normal to run because I had two other resource hungry processes running in parallel with it. Hopefully the 18z will run at more like normal speed.
even wxcharts.com GFS is out of date
