McMahon - ECMWF Mix Run 18 z Missing - Last was 2023-07-06-06 z
McMahon - Last Good ECMWF Mix Run was ( 2023-07-06-06 z ) and Last Should Be ( 2023-07-06-18 z ).
It is possible that the Data is running Late.
Kindest Regards,
Tony
I’ve just remembered that the ECMWF provided scripts have a fault that means the 18z run isn’t properly discovered. I need to apply the same fix to the new server as I did on the old one. 00z will be here soon so I’ll be able to fix the scripts once I get out of bed, i.e. before the next 18z run.
I’ve applied the patch so the 18z run should be OK now. I did report the fix in github but I suspect that the ECMWF developers don’t look at reports on there. I don’t know why they use github and then ignore bug reports though.
Confirm 00z available, though sadly about 1 minute after my auto run. :slight_smile:
I’ve just made my first ever github contribution. There’s a pull request in the queue for the ECMWF scripts that should fix the 18z issue. I don’t k now if/when the ECMWF admins will approve/incorporate the fix but I’ve tried my best.
