McMahon - Last Good ECMWF Mix Run was ( 2023-10-31-00 z ) and Last Should Be ( 2023-10-31-12 z ).
It is possible that the Data is running Late.
Kindest Regards,
Tony
12z was still running when I left the laptop. The data was very slow to download with numerous restarts. I don’t know why that was happening though.
Hi Chris,
Appreciate that, i’m currently out will be back in about 5 hours.
Should be home before next Run at least.
Kindest regards,
Tony
OK so I confirm ECMWF Mix Run 2023-10-31-18-z was available, for my scheduled run anyway. My run was 2013-11-01 03:06:00 UTC.
Note: looked all over web could not find any issues with ECMWF ?
Kindest Regards,
Tony
If 18Z was on time then that suggests a temporary network blip that may have been solved now. I’ll try to take a look later today although I’ve got a fairly busy day planned with non-computer related activities.
I’m assuming that ECMWF data is currently appearing on-time as there are no more reports. I guess there was a temporary network issue somewhere between my server and the ECMWF data sources.
I know GFS used to suffer from similar issues from time to time. They solved the problem by moving to a CDN based distribution process. It’s been very stable since then.
