McMahon - ECMWF Mix Run 12 z Missing - Last was 2023-06-28-06 z
McMahon - Last Good ECMWF Mix Run was ( 2023-06-28-06
z ) and Last Should Be ( 12 z )
It is possible that the Data is running Late.
Kindest Regards,
Tony
Looks like the data availability is delayed beyond what we’ve previously expected. We might need to re-assess the data availability times when the upgrade dust has settled.
Hi Chris,
Thanks for all the updates, appreciated.
Do you want me to stop the auto post checks and just auto email you or let them run as is for now.
At least I can confirm 2023-06-28-06 downloaded OK. :grinning:
Let them run for now. If people come looking for answers to why ECMWF data isn’t available they’ll see the posts. Between us we can try to update the automatic posts with details of when the data actually becomes available. Then we can tweak the timing once we’ve got a better idea of when data is available in the post-upgrade world.
If I get a chance tomorrow I’ll see if I can create a test script that checks every 5 minutes to see what the latest version is and log it to a file. That will make it a bit easier to figure out when data becomes visible…it will take some extra time for me to download and process the data, but that’s a fairly fixed time so data visibility time is probably the key factor.
OK thanks Chris.
I do do some similar checks though only after WXSIM has run, so may look at an additional check 5 minutely as well if I flag it missed.
One issue I have is that I have been unable to return the auto posted topic id when auto posting, so will not be able to update same Original Missing Post !
I suppose it would not matter is a new topic auto posted stating “x Run is now available” (if a previous auto post flagged it missing) if that makes sense, I can easily do that.
