McMahon - Last Good ECMWF Mix Run was ( 2023-10-31-00 z ) and Last Should Be ( 2023-10-31-06 z ).
It is possible that the Data is running Late.
Kindest Regards,
Tony
It looks like it’s available now.
I’ve got it appearing between 15:15 and 15:30 GMT today.
My quick check suggested about 15:24 but Iwas rushing out so it wasn’t an in-depth analysis
I run a check every 15 minutes which I started to allow me to fine tune my forecast timings.
Hi Just woke up.
Yes confirm ECMWF Mix Run 2023-10-31-06-z was around 2 hours late roughly.
Will advise if ECMWF Mix Run 2023-10-31-12-z is on time.
Kindest Regards,
Tony
I just looked - the data arrived 90 minutes late. I’ve no way to find out why though.
I think there must be some network problems. The 12z data is currently downloading, or rather not downloading. I can see the files but the download is stuttering along and hanging up at times. When it is running it’s also pretty slow with lots of connection retries.
EDIT: As an example of what I mean…on a normal run I can get 10+ multi-megabyte data files downloaded per minute. At the moment it’s taking 2+ minutes to download a single file.
