McMahon - Last Good ECMWF Mix Run was ( 2023-10-11-18 z ) and Last Should Be ( 2023-10-12-00 z ).
It is possible that the Data is running Late.
Kindest Regards,
Tony
I’m enjoying lunch next to a market which had been running since the 12th century so I’m not able to easily check this right now.
The 12th 00z ECMWF data was available by 10:30 BST this morning.
I checked my data for the past few days and it seems like the ECMWF data has been delayed a bit over the previous 3 days.
Hi Chris/Stuart,
Sorry late response I was in land of nod when you where lunching in your 12th Century market.
I corrected the Date Issue (2023-10-11-00 z vs should have been 2023-10-12-00 z), found reason to be that when I had no choice other than to push my wxsim runs back one hour when we moved to DST at the start of this month due to data being later than in previous years, I had to modify numerous scripts and crons and missed two cron checks for WD Api Posts, have now fixed. Also corrected first post above.
The other point here being as Stuart has pointed out, it has been late recently, the fact I have not auto posted issues is because I am now running 1 hour later than many users, they would have had issues but I did not until this one, which means it was running really late.
Kindest Regards,
Tony
