McMahon - Last Good ECMWF was ( 2024062000 z ) and Last Should Be ( 2024062006 z )
Note: this was Checked at 2024-06-20 15:00 UTC.
It is possible that the Data was running Late and may now be available.
Kindest Regards,
Tony
I’m working on this. I had to rescale the servers to add extra disk because they kept on running out of space. That’s upset some things!
I’m busy learning new stuff!
The replicated data across the three servers is stored in 18 volumes (6 per server) which each have indexes. Two of the indexes had become corrupt, probably during the rescaling, which made those two volumes read-only, which in turn made writing data to the shared disk unstable.
I’ve learned how to fix the corruption now, so if it happens again I’ll know what to do.
The servers seem to be back to normal now, but they’ll take a little while to catch up, e.g. they will need to run the missed ECMWF data run.
The 06z ECMWF data is available now. The 12z hasn’t been missed…it’s not due to start for about another 30 minutes.
