McMahon ECMWF 2023121118 z Missing - Last was 2023121112 z
McMahon - Last Good ECMWF was ( 2023121112 z ) and Last Should Be ( 2023121118 z )
Note: this was Checked at 2023-12-12 02:00 UTC.
It is possible that the Data was running Late and may now be available.
Kindest Regards,
Tony
Took screen dump below at UTC 02:19 (Still Running.
Hi Chris, just on that it would be great to have a Current UTC Date/Time Stamp at the Top above the Tables for quick ref.
Kindest Regards,
Tony.
The processing took an hour longer than normal for some reason. I’ll see if I can work out why later, and also add a timestamp onto the stats page.
It’s going to be quite a lot later when I can look at it. Just woke up at 4am to go to the airport to pick someone up :sleeping::sleeping::sleeping:
Oh dear it just happened again, you poor thing, take care.
I can see some disk management activity happening in the background. It’s been running for some time and it’s possibly slowing the server down. That could be why the processing jobs are taking longer because they are very computationally anddisk intensive so something keeping the CPU and disk busy would slow them down more than other server based activities. It’s looking like the process won’t finish for about 10 hours so the next couple of runs of both GFS and ECMWF may be delayed.
