McMahon - Last Good ECMWF was ( 2023111606 z ) and Last Should Be ( 2023111612 z )
Note: this was Checked at 2023-11-16 21:06 UTC.
It is possible that the Data was running Late and may now be available.
Kindest Regards,
Tony
Hi Chris,
From what I can tell this is correct and the ECMWF (12z) is still missing at time of this post.
Note: The initial post above is from my new single GFS/ECMWF check script.
Not my old checks that run after my Forecast and check if correct data was used, these check if the (date/run) is available by the weather-watch gfsn and ecmwf reports. I did send you and Stuart messages on the forum though not heard back, maybe the messages did not get received.
New McMahon Check Outputs on my weather site : McMahon Checks
Kindest Regards,
Tony
I now confirm ECMWF 2023111612z is now available.
Looking at Stuarts Logs, somewhere between 23:30 and 23:45 (I assume they are UTC times Stuart)?
16/11/23 23:30 GFS 2023111618 ---- ECMWF 2023111606
16/11/23 23:45 GFS 2023111618 ---- ECMWF 2023111612
Kindest Regards,
Tony
Sorry, busy day yesterday so I’m only just catching up. Rainy day today so I’m hoping for more keyboard time
