Max gust speed time not updating, heating degree days not adding up properly
10.37f build 15
Peet Ultimeter 2100, Belkin serial to USB adapter, complete record mode.
WinXP, 300MB+ RAM, dedicated to WD
Heating degrees for the month don’t add up,
http://home.earthlink.net/~gerardhome/climatedataout.html and
http://home.earthlink.net/~gerardhome/dailynoaareport.htm
also, the main screen “maximum gust since midnight”, “maximum gust today” time does not update. It seems to stay at some wee hours time like 12:30AM or similar even though a higher gust occurs later on in the day. The proper gust speed is recorded, but not the time.
the gust time problem is problem when using complete record mode
( i need to work with someone on that problem)
for the first problem, i would need your data file month92007.inf
File zipped and sent. Count me in if you need help with the Peet complete record mode.
