Is there a way to reset the main screen back to it’s original settings. I screwed it up and now I can’t get back to the standard layout.
And advice would be appreciated.
John
John
have you checked out http://discourse.weather-watch.com/t/14157
there seems to be some verbage there about starting over
Thanks for the advise, I checked but I can’t get the screen to go back to it’s original state. I have a backup of the entire WD directory and was wondering if there was one file that could be replaced???
John
If it were me I would try the following.
Install a test copy of WD so you now have 2 copies. The new copy will have a new ini file. You can then get the data from the original copy and customize as you see fit. There is an FAQ on how to do this here http://discourse.weather-watch.com/t/10889
There are some client/server issues that you may encounter depending upon how you choose to get your data. Doing a search on terms like client server and then weeding thru the responses will show you how to set up such a system.
hope this helps
To reset the Main WD screen you have to delete a registry entry. Try this thread:
http://discourse.weather-watch.com/p/85427
Hope this helps.
Bill
Thanks everyone ---- that fixed it.
John
