cardinal sin, I was recently playing around with the WD main screen consul with some custom setups which I now don’t like. I would like to revert back to the original, unfortunatly I did not save a copy of the registry entry
Is there a simple way of doing this without losing any data from the registry
I’ve never had the occasion to use it but there’s a “start over main” button on the Main Window Customize screen which I’ve seen Brian recommend before.
- Jim
Your options would be:
There is an option under “Setup - Extra Settings/Misc” called “Start Over”
If that doesn’t work then the other option is:
Excellent, thanks guys “start over” worked a treat
