I would delete the wdisplay folder in the library location (from an older version)
(when WD is not running)
so that it then correctly creates a wdisplay folder in
users/[yourusename]/Documents/
when you start WD
you should be selecting the .cu driver listed
in any case, I wonder if there is a permissions problem
you could try running the exe file direct from a terminal window
(in the application bundle, Contents, MacOS folder
Wow, that CU type actually fixed the problem… I’m getting data now, but have lost my registered version when I deleted my old files.
Sent you email with code that shows
