Hi there
is there a way in the PWS dashboard (I’m sure there is) a way to change the refresh time for the file luftdaten from 2 minutes to 5 or 10 minutes?
Reason is as its set to 2 mins it never updates in PWS dashboard until at least 7 - 8 mins, so therefore lately there is always a red exclamation mark. I tried deleting the status.arr file but it makes no difference. ( have looked at all the load files etc with no luck).
WIM will know im sure…
Around line 51 of PWS_settings.php, I think:
$luftRefresh = 120;
I think you need to delete status.arr again after making the change. . .
Right that’s the only file i didn’t look at, didn’t think it was in there. Well Done BOS.
Just changed the refresh, so wait and see now
Hi all
question about this one again.
I changed the settings as BOS said to 10 mins, deleted the file, and now the update time has changed from 2 mins to 3 mins 20 seconds?, is there anywhere else that needs to be changed,
Ideas on a a postcard please…
Around line 90 of PWS_blocks.php I have
$rfrsh_AQ = 300;
which is the block refresh time, not the data refresh time. . .?
EDIT: I think the cron brings the data refresh time down: around line 33 in PWS_load_files.php we have
if (isset ($cron) && $cron == true) {$times = 0.8;} else {$times = 1;}
and around line 340
$allowed_age = $luftRefresh*$times;
In the cron job, 80% of the set time is used → 480 seconds == 8 mintues
PWS_load_files.php (470) AQ-Luftdaten__: File not old enough (147/480 seconds) https://data.sensor.community/airrohr/v1/sensor/64838/
If the dashboard is used, for every on-line user, the PWS_load_files is run (jQuery) every 120 seconds but the allowed age for the file is 600 seconds == 10 minutes
PWS_load_files.php (470) AQ-Luftdaten__: File not old enough (454/600 seconds) https://data.sensor.community/airrohr/v1/sensor/64838/ P
In the status popup, only updated by the cron job, it shows when I check,
./jsondata/luftdaten.txt aq-luftdaten Ok 4 mins 28 seconds https://data.sensor.community/ . . .
So where is the age of 3 min 20 seconds displayed?
Then i can check.
Hi Wim
seems to be ok now that i have changed some settings as BOS said.
It showed up in the status popup page saying max time 3 mins 20 secs
