hi i have a problem with the luftdatem AQ block; when i click on the"map" link , i have a blank page; this is the link of my website www.meteoalne.altervista.org
this is the link of the popup
can you help me?
can you help me?
You modified $scrpt_vrsn_dt = 'PWS_frames.php|01|2021-11-30|
on line 97 is missing an ending ;
character just between the '
and the #
$frm_src[$frame] = 'https://www.yr.no/en/print/forecast/2-3164388/Italy/Veneto/Province of Treviso/Vidor' #'https://retro.yr.no/place/'.$yrno_area.'/forecast.pdf'; #### 2021-03-27
This will give a PHP parser error on the next line
Parse error : syntax error, unexpected variable “$frm_frme” in /membri/meteoalne/PWS_frames.php on line 98
Change that line to
$frm_src[$frame] = 'https://www.yr.no/en/print/forecast/2-3164388/Italy/Veneto/Province of Treviso/Vidor' ; #'https://retro.yr.no/place/'.$yrno_area.'/forecast.pdf'; #### 2021-03-27
You can test these modifications by using the &test option on a link.
Example you posted
https://www.meteoalne.altervista.org/index.php?frame=airqualityLD&theme=dark&lang=it-it&units=metric
Adding the &test
https://www.meteoalne.altervista.org/index.php?frame=airqualityLD&theme=dark&lang=it-it&units=metric&test
will show almost all errors
thanks a lot Vim; i fixed the code and now the error is gone, but the “map” link in the Luftdatem Block doesn’t work anyway; The target page now it’s not blank, but it brings me to the “Home”
here it is a WORKING example of the frame, i took it in a website of a weather station located near me
