Lora
Hi All,
Is there any WD support for these types of wireless Lora modules to use with my 1-wire network? Low-Power LoRa Node with 1-Wire Temperature Sensors - Hackster.io
Thanks in advance.
see in the setup, advanced misc, temperature tab, very bottom
Thanks Brian. Is there some kind of setup instructions on setup? Can you run Humidty etc as well.
you would just need to know the IP address, set as lowran type
its only designed currently to allocate the reading to an extra temperature number that you set
