windy2
8 October 2015 19:12
681
the problem seems to be that the data logger keeps on sending the LOOP data
i.e it seems to be that is being sent even when WD first starts up…hence why I ask is there any other software running, requesting that
eventually that stops and the expected answer is given:
Davis VP Retrieving data from: day 8 month 10 year 2015
Retrieving data from: hour 18 minute 6
ask for time/date of record…
16
2 1
30
4 1
50
6 69
7*133
Sending OK…
and then actual history data should be returned…but it does not look correct
see if the original WD mac version provides this raw data, so we can compare
windy2
8 October 2015 19:36
682
also maybe if you could .zip and email me your settings files, I could test here
Oh this is SO, SO frustrating.
Definitely exactly the same symptoms as DeputyDawg had.
Also, FYI, the Exit button DOES NOT work at all from time to time. So that clearly is not permanently fixed in 249.
I also tested with the same files and the original Mac version. It also does not work.
If someone could suggest WHAT is getting corrupted in these files or how cronrealftp is getting the wrong info, I would appreciate it.
Regds,
dave
Doggy… not sure exactly what fixed mine. But it was definitely corruption in the wdisplayftp.ini file
I THINk it was section:
[Connections]
other client ftp server=gator4240.hostgator.com
other client ftp username=paul
other client ftp password=blankedout
other client ftp remote directory=/public_html
create custom clientraw=no
create custom clientraw update rate=5
create custom clientraw upload rate=5
clienraw 2nd copy=no
other client ftp server2=
other client ftp username2=
other client ftp password2=
other client ftp remote directory2=
other client ftp remote name2=
StationName=noname
use FTPS=no
check CWD=no
use passive=yes
use rename=no
no night upload=no
FTPHost=gator4240.hostgator.com
FTPUsername=paul
FTPPassword=blankedout
RemoteDir=/public_html
FTP Port=21
show summary from metar=no
use coded to update icon=no
Check to make sure all your host names passwords etc look good. Restore from a very old copy if you have to
Also I doubt this was another area to check but you might as well
[New webfiles location]
client raw location=/Users/Paul/Documents/wdisplay/webfiles/
I had one of the above lines messed up
let me know - either here or PM if that helps or not
vk2him
8 October 2015 22:43
684
Weather Display post:682:
I couldn’t find a button to save the required files, so I’ve selected some manually - hopefully I did the right ones and i just emailed them to you
Cheers
windy2
8 October 2015 23:09
685
@vk2him
your settings files work OK here (I changed the IP address in the WDISPLAY.INI before starting it up)
have you tried a longer than 5 minute down time?
windy2
8 October 2015 23:47
686
one good thing is I have fixed the exit error, for the next update
Hi Brian WD MacB250 Version on 4 October 2015 - 23:42:35 - 2 day with FWI updates off and all is Good with WD no noon shut downs.
BTrip
vk2him
9 October 2015 00:44
688
Interesting - I had it off for about 15 minutes and this time it worked …
Loaded all time records
Loaded units
Asking for archived data download
TCP/IP connected to 192.168.1.61
logfile count 0
re starting download, timer
sending DMPAFT
176
2 79
379
4 0
50
6 153
76
Davis VP Retrieving data from: day 9 month 10 year 2015
Retrieving data from: hour 11 minute 29
1 10
2119
3 215
42
5 48
6212
7 2
#2Command not understood, restarting
0 10 119 215 2 48 212 2
sending DMPAFT
10
2 4
334
4 0
5255
6 255
7255
8 255
9255
10 255
11255
12 255
13255
14 255
15255
16 255
17255
18 255
19255
20 56
21255
22 255
23255
24 255
25255
26 255
27255
28 0
290
30 61
3167
32 3
330
34 0
35255
36 255
370
38 0
390
40 0
41187
42 19
4354
44 0
45124
46 0
47139
48 12
49255
50 255
51255
52 255
53255
54 255
55255
56 0
570
58 0
590
60 0
610
62 0
630
64 0
650
66 0
670
68 0
690
70 0
710
72 0
730
74 7
753
76 6
19
2 11
32
4 13
57
6 10
713
0 9 11 2 13 7 10 13
sending DMPAFT
1 10
2112
3 76
479
5 79
60
7 0
8153
9 6
110
2 119
3215
4 2
548
6 212
72
sending DMPAFT
1 1
24
3 90
41
5 255
6255
7 255
8255
9 255
10255
11 255
12255
13 255
14255
15 255
16255
17 255
18255
19 255
2056
21 255
22255
23 255
24255
25 255
26255
27 255
280
29 0
3061
31 67
323
33 0
340
35 255
36255
37 0
380
39 0
400
41 187
4219
43 54
440
45 124
460
47 139
4812
49 255
50255
51 255
52255
53 255
54255
55 255
560
57 0
580
59 0
600
61 0
620
63 0
640
65 0
660
67 0
680
69 0
700
71 0
720
73 0
747
75 3
766
1 9
211
3 2
413
5 7
610
7 13
0 9 11 2 13 7 10 13
sending DMPAFT
1184
2 112
376
4 79
579
6 0
70
8 153
96
1 10
2119
3 215
42
5 48
6212
7 2
sending DMPAFT
11
2 4
381
4 1
5255
6 255
7255
8 255
9255
10 255
11255
12 255
13255
14 255
15255
16 255
17255
18 255
19255
20 56
21255
22 255
23255
24 255
25255
26 255
27255
28 0
290
30 61
3167
32 3
330
34 0
35255
36 255
370
38 0
390
40 0
41187
42 19
4354
44 0
45124
46 0
47139
48 12
49255
50 255
51255
52 255
53255
54 255
55255
56 0
570
58 0
590
60 0
610
62 0
630
64 0
650
66 0
670
68 0
690
70 0
710
72 0
730
74 7
753
76 6
19
2 11
32
4 13
57
6 10
713
0 9 11 2 13 7 10 13
sending DMPAFT
1 172
243
3 76
479
5 79
60
7 0
8153
9 6
110
2 119
3215
4 2
548
6 212
72
sending DMPAFT
1 2
24
3 76
41
5 255
6255
7 255
8255
9 255
10255
11 255
12255
13 255
14255
15 255
16255
17 255
18255
19 255
2056
21 255
22255
23 255
24255
25 255
26255
27 255
280
29 0
3061
31 67
323
33 0
340
35 255
36255
37 0
380
39 0
400
41 187
4219
43 54
440
45 124
460
47 139
4812
49 255
50255
51 255
52255
53 255
54255
55 255
560
57 0
580
59 0
600
61 0
620
63 0
640
65 0
660
67 0
680
69 0
700
71 0
720
73 0
747
75 3
766
1 9
211
3 2
413
5 7
610
7 13
0 9 11 2 13 7 10 13
sending DMPAFT
1179
2 224
376
4 79
579
6 0
70
8 153
96
1 10
2119
3 215
42
5 48
6212
7 2
sending DMPAFT
12
2 4
376
4 1
5255
6 255
7255
8 255
9255
10 255
11255
12 255
13255
14 255
15255
16 255
17255
18 255
19255
20 56
21255
22 255
23255
24 255
25255
26 255
27255
28 0
290
30 61
3167
32 3
330
34 0
35255
36 255
370
38 0
390
40 0
41187
42 19
4354
44 0
45124
46 0
47139
48 12
49255
50 255
51255
52 255
53255
54 255
55255
56 0
570
58 0
590
60 0
610
62 0
630
64 0
650
66 0
670
68 0
690
70 0
710
72 0
730
74 7
753
76 6
19
2 11
32
4 13
57
6 10
713
0 9 11 2 13 7 10 13
sending DMPAFT
1 179
2224
3 76
479
5 79
60
7 0
80
9 10
1013
11 6
16
2 4
30
4 4
50
6 6
753
Sending OK…
8 10
913
10 6
1124
12 10
1313
14 10
1513
16 6
1724
18 10
1913
20 10
2113
22 6
2324
24 10
2513
26 10
2713
28 6
2924
30 6
316
32 4
330
34 4
350
36 6
3753
38 10
3913
40 0
logfile count 0
416
42 6
434
44 0
454
46 0
476
48 53
490
50 73
5131
52 102
534
54 210
552
56 210
572
58 209
592
60 0
610
62 0
630
64 14
65119
66 62
673
68 24
690
70 215
712
72 48
7356
74 4
758
76 0
771
78 60
790
80 62
813
82 60
839
84 255
85255
86 255
87255
88 255
89255
90 255
91255
92 0
93255
94 255
95255
96 255
97255
98 255
99255
100 255
101255
102 73
10331
formating data
Time :11:26
Date :09/10/2015
104 103
105 4
106 211
107 2
108211
109 2
110210
111 2
1120
113 0
1140
115 0
11613
117 119
11863
119 3
12023
121 0
122215
123 2
12448
125 57
1265
127 9
1281
129 1
13060
131 0
13263
133 3
13460
135 9
136255
137 255
138255
139 255
140255
141 255
142255
143 255
1440
145 255
146255
147 255
148255
149 255
150255
151 255
152255
153 255
15473
155 31
formating data
Time :11:27
Date :09/10/2015
156 104
157 4
158 212
1592
160 212
1612
162 211
1632
164 0
1650
166 0
1670
168 13
169119
170 65
1713
172 23
1730
174 215
1752
176 48
17756
178 6
17912
180 2
18115
182 60
1830
184 65
1853
186 60
1879
188 255
189255
190 255
191255
192 255
193255
194 255
195255
196 0
197255
198 255
199255
200 255
201255
202 255
203255
204 255
205255
206 73
20731
formating data
Time :11:28
Date :09/10/2015
208 105
209 4
210 212
211 2
212212
213 2
214212
215 2
2160
217 0
2180
219 0
22012
221 119
22265
223 3
22424
225 0
226215
227 2
22848
229 56
2307
231 12
23215
233 0
23460
235 0
23665
237 3
23860
239 9
240255
241 255
242255
243 255
244255
245 255
246255
247 255
2480
249 255
250255
251 255
252255
253 255
254255
255 255
256255
257 255
25873
259 31
formating data
Time :11:29
Date :09/10/2015
260 106
261 4
262 212
2632
264 212
2652
266 212
2672
268 0
2690
270 0
2710
272 10
273119
274 67
2753
276 23
2770
278 215
2792
280 48
28156
282 6
28320
284 0
2850
286 61
2870
288 67
2893
290 61
2919
292 255
293255
294 255
295255
296 255
297255
298 255
299255
300 0
301255
302 255
303255
304 255
305255
306 255
307255
308 255
309255
310 255
311255
formating data
Time :11:30
Date :09/10/2015
finished data block
1 255
2 255
3 215
4142
5 0
sending OK after 5 blocks of data *
11
2 73
331
4 107
54
6 212
72
8 212
92
10 212
112
12 0
130
14 0
150
16 13
17119
18 69
193
20 24
210
22 215
232
24 48
2556
26 6
2716
28 15
2915
30 61
310
32 69
333
34 61
359
36 255
37255
38 255
39255
40 255
41255
42 255
43255
44 0
45255
46 255
47255
48 255
49255
50 255
51255
52 255
53255
54 73
5531
formating data
Time :11:31
Date :09/10/2015
56 108
57 4
58 212
59 2
60212
61 2
62212
63 2
640
65 0
660
67 0
6813
69 119
7072
71 3
7221
73 0
74215
75 2
7648
77 56
785
79 10
800
81 2
8261
83 0
8472
85 3
8661
87 9
88255
89 255
90255
91 255
92255
93 255
94255
95 255
960
97 255
98255
99 255
100255
101 255
102255
103 255
104255
105 255
10673
107 31
formating data
Time :11:32
Date :09/10/2015
108 109
109 4
110 212
1112
112 212
1132
114 212
1152
116 0
1170
118 0
1190
120 11
121119
122 76
1233
124 23
1250
126 215
1272
128 48
12956
130 4
1319
132 0
1331
134 61
1350
136 76
1373
138 61
1399
140 255
141255
142 255
143255
144 255
145255
146 255
147255
148 0
149255
150 255
151255
152 255
153255
154 255
155255
156 255
157255
158 73
15931
formating data
Time :11:33
Date :09/10/2015
160 110
161 4
162 213
163 2
164213
165 2
166212
167 2
1680
169 0
1700
171 0
17212
173 119
17478
175 3
17624
177 0
178215
179 2
18048
181 56
1824
183 10
1841
185 15
18662
187 0
18878
189 3
19062
191 9
192255
193 255
194255
195 255
196255
197 255
198255
199 255
2000
201 255
202255
203 255
204255
205 255
206255
207 255
208255
209 255
21073
211 31
formating data
Time :11:34
Date :09/10/2015
212 111
213 4
214 213
2152
216 213
2172
218 213
2192
220 0
2210
222 0
2230
224 11
225119
226 79
2273
228 23
2290
230 215
2312
232 48
23356
234 5
23511
236 0
2370
238 62
2390
240 79
2413
242 62
2439
244 255
245255
246 255
247255
248 255
249255
250 255
251255
252 0
253255
254 255
255255
256 255
257255
258 255
259255
260 255
261255
262 255
263255
formating data
Time :11:35
Date :09/10/2015
finished data block
1 255
2 255
3 230
4139
5 255
12
2 73
331
4 112
54
6 212
72
8 213
92
10 212
112
12 0
130
14 0
150
16 8
17119
18 79
193
20 24
210
22 217
232
24 48
2556
26 9
2717
28 15
2914
30 62
310
32 79
333
34 62
359
36 255
37255
38 255
39255
40 255
41255
42 255
43255
44 0
45255
46 255
47255
48 255
49255
50 255
51255
52 255
53255
54 73
5531
formating data
Time :11:36
Date :09/10/2015
56 113
57 4
58 212
59 2
60212
61 2
62212
63 2
640
65 0
660
67 0
688
69 119
7079
71 3
7223
73 0
74217
75 2
7648
77 56
782
79 8
8014
81 0
8262
83 0
8479
85 3
8662
87 9
88255
89 255
90255
91 255
92255
93 255
94255
95 255
960
97 255
98255
99 255
100255
101 255
102255
103 255
104255
105 255
10673
107 31
formating data
Time :11:37
Date :09/10/2015
108 114
109 4
110 212
1112
112 212
1132
114 212
1152
116 0
1170
118 0
1190
120 5
121119
122 81
1233
124 24
1250
126 217
1272
128 48
12956
130 4
13110
132 14
13315
134 63
1350
136 81
1373
138 63
1399
140 255
141255
142 255
143255
144 255
145255
146 255
147255
148 0
149255
150 255
151255
152 255
153255
154 255
155255
156 255
157255
158 73
15931
formating data
Time :11:38
Date :09/10/2015
160 115
161 4
162 212
163 2
164212
165 2
166212
167 2
1680
169 0
1700
171 0
1728
173 119
17481
175 3
17623
177 0
178217
179 2
18048
181 56
1827
183 11
18414
185 15
18663
187 0
18881
189 3
19063
191 9
192255
193 255
194255
195 255
196255
197 255
198255
199 255
2000
201 255
202255
203 255
204255
205 255
206255
207 255
208255
209 255
21073
211 31
formating data
Time :11:39
Date :09/10/2015
212 116
213 4
214 213
2152
216 213
2172
218 212
2192
220 0
2210
222 0
2230
224 6
225119
226 85
2273
228 23
2290
230 217
2312
232 48
23356
234 4
2358
236 14
23715
238 63
2390
240 85
2413
242 63
2439
244 255
245255
246 255
247255
248 255
249255
250 255
251255
252 0
253255
254 255
255255
256 255
257255
258 255
259255
260 255
261255
262 255
263255
formating data
Time :11:40
Date :09/10/2015
finished data block
1 255
2 255
3 70
437
5 255
13
2 73
331
4 117
54
6 214
72
8 214
92
10 213
112
12 0
130
14 0
150
16 6
17119
18 85
193
20 24
210
22 217
232
24 48
2557
26 4
2710
28 2
292
30 63
310
32 85
333
34 63
359
36 255
37255
38 255
39255
40 255
41255
42 255
43255
44 0
45255
46 255
47255
48 255
49255
50 255
51255
52 255
53255
54 71
5531
formating data
Time :11:41
Date :09/10/2015
56 166
57 6
58 126
59 2
60127
61 2
62126
63 2
640
65 0
660
67 0
68100
69 119
7013
71 1
7223
73 0
74244
75 2
7648
77 61
784
79 9
8010
81 8
8213
83 0
8438
85 1
8613
87 9
88255
89 255
90255
91 255
92255
93 255
94255
95 255
960
97 255
98255
99 255
100255
101 255
102255
103 255
104255
105 255
10671
107 31
formating data
Time :17:02
Date :07/10/2015
108 167
109 6
110 126
1112
112 126
1132
114 126
1152
116 0
1170
118 0
1190
120 101
121119
122 251
1230
124 24
1250
126 244
1272
128 48
12960
130 3
1319
132 8
1339
134 13
1350
136 251
1370
138 14
1399
140 255
141255
142 255
143255
144 255
145255
146 255
147255
148 0
149255
150 255
151255
152 255
153255
154 255
155255
156 255
157255
158 71
15931
formating data
Time :17:03
Date :07/10/2015
160 168
161 6
162 125
163 2
164126
165 2
166125
167 2
1680
169 0
1700
171 0
17299
173 119
174251
175 0
17616
177 0
178244
179 2
18048
181 61
1826
183 14
1849
185 9
18612
187 0
188251
189 0
19012
191 9
192255
193 255
194255
195 255
196255
197 255
198255
199 255
2000
201 255
202255
203 255
204255
205 255
206255
207 255
208255
209 255
21071
211 31
formating data
Time :17:04
Date :07/10/2015
212 169
213 6
214 124
2152
216 125
2172
218 124
2192
220 0
2210
222 0
2230
224 99
225119
226 162
2270
228 23
2290
230 244
2312
232 48
23361
234 2
2355
236 9
2379
238 11
2390
240 162
2410
242 11
2439
244 255
245255
246 255
247255
248 255
249255
250 255
251255
252 0
253255
254 255
255255
256 255
257255
258 255
259255
260 255
261255
262 255
263255
formating data
Time :17:05
Date :07/10/2015
finished data block
1 255
2 255
3 36
4215
5 255
Aborted
All data downloaded or did not sync correct!
formating the VP data
vp data read in 12
VP data Date:= 9/10/2015
VP data Time:= 11:30
Rain in davis VP download added :0.0
VP data Time:= 11:31
VP data Time:= 11:32
VP data Time:= 11:33
VP data Time:= 11:34
VP data Time:= 11:35
VP data Time:= 11:36
VP data Time:= 11:37
VP data Time:= 11:38
VP data Time:= 11:39
VP data Time:= 11:40
Weather station type number 31
logfile count 3
logfile count 3
logfile count 3
VP reception #1 16301 #2 76 = 100
logfile count 5
logfile count 5
logfile count 5
logfile count 5
logfile count 5
logfile count 5
logfile count 5
logfile count 5
logfile count 5
windy2
9 October 2015 01:56
689
thats good
I think the problem is , was the LOOP data was still being sent…that times out eventually
I need to have a way of sending a command to stop that, or similar
Hi Brian WD MacB250 Version on 4 October 2015 - 23:42:35 - 4 days with FWI updates off and all is Good with WD no noon shut downs.
BTrip
windy2
10 October 2015 21:32
691
keep that going another day or 2 just to make sure
but its looking like that is where the problem is, which narrows things down for me
Hey Brian
Just thought I would mention I have had a couple of Noon time crashes. I’m pretty sure you said that was due to some forest fire update or something.
I’m on the latest build 250
windy2
11 October 2015 22:14
693
yes, see further up the thread:
turning off the FWI updates fixes that (would be good if you can confirm that too)
Gosh… I hate to even ask this
But I have never heard of FWI let alone how to turn it off or on
windy2
11 October 2015 22:40
695
view
fire weather index
turn the switch off thre
Thanks, its now OFF
something that will be addressed in the future?
Curious why it doesn’t crash every day at noon then??
windy2
12 October 2015 07:48
698
build 251 ready
added in more moon and associated calculations/custom tags that were missing…
and made a change that should help with the FWI noon update problem
also fix for humidity data from Acurite station
Just updated to B151 - also put the FWI back on - see what happens
Thanks Brian !!!
Btw exit hasn’t been working for some time now - no biggie, just mentioning it
Hi Brian updated to WD-Mac-B251. Thanks for the tags.
BTrip
