Deputydewarg had this problem
the wdisplayftp.ini file was getting corrupted on WD start up
copying a back up of that after WD has started up I think was the solution…try that
@vk2him
I have done a test of a history data download at start up with my IP data logger
and it did work
what shows under view, debug info?
No luck with replacing the wdisplayftp.ini as suggested. Tried it several times with a backup copy form 24hrs before the problem started.
Still no uploads! Now almost 48hrs off the air.
I have had a look at the file wth an editor but cannot see anything wrong. However, spotting it would probably be very, very difficult.
Dave
Oh this is SO, SO frustrating.
Definitely exactly the same symptoms as DeputyDawg had.
Also, FYI, the Exit button DOES NOT work at all from time to time. So that clearly is not permanently fixed in 249.
I also tested with the same files and the original Mac version. It also does not work.
If someone could suggest WHAT is getting corrupted in these files or how cronrealftp is getting the wrong info, I would appreciate it.
Regds,
dave
It shows this:
Loaded all time records
Loaded units
Asking for archived data download
TCP/IP connected to 192.168.1.61
re starting download, timer
sending DMPAFT
Davis VP Retrieving data from: day 6 month 10 year 2015
Retrieving data from: hour 19 minute 44
ask for time/date of record…
#2Command not understood, restarting
sending DMPAFT
Sending OK…
Aborted
All data downloaded or did not sync correct!
formating the VP data
vp data read in 1
Weather station type number 31
VP reception #1 27615 #2 177 = 99
VP reception #1 27636 #2 177 = 99
VP reception #1 27659 #2 177 = 99
Hi Brian WD MacB250 Version on 4 October 2015 - 23:42:35 shut down @ noon today. Had to restart WD all seems fine.
There was nothing in program error log.
BTrip
sending DMPAFT
that is the clue there…the response back is not what was expected
I have tested a number of times and it works here
but I will add some debug code to see what data is being returned on your setup
@bdtripps
it would be interesting to know if the problem is the FWI (i.e try turning the updates that off as a test)
@doggy
did you find a backup of the wdisplayftp.ini file?
does the ftp settings show up OK in WD itself?
one thing I could do is to get the cronftp to use a different ftp ini file (i.e a copy…creatd before WD uses it)
Hi Brian I shut off FWI updates and restarted WD.
BTrip
Thanks Brian - this is what now shows:
Loaded units
sending DMPAFT
Davis VP Retrieving data from: day 7 month 10 year 2015
Retrieving data from: hour 15 minute 15
0 89 119 233 2 47 106 2
sending DMPAFT
0 9 14 2 12 7 10 13
sending DMPAFT
sending DMPAFT
0 9 14 2 12 7 10 13
sending DMPAFT
sending DMPAFT
0 9 14 2 12 7 10 13
sending DMPAFT
sending DMPAFT
0 9 14 2 12 7 10 13
sending DMPAFT
sending DMPAFT
0 9 14 2 12 7 10 13
sending DMPAFT
0 1 0 0 0 118 180 10
sending DMPAFT
Sending OK…
Aborted
vp data read in 1
VP reception #1 12948 #2 65 = 100
do you have the IP data logger set to send to weatherlink.com by any chance?
also how long did you have WD not running for?
No, I’m not sending to weatherlink.com - the IP Datalogger is only accessed locally by WD on th3 same network. WD was off for approx 5 mins - thanks
any other software accessing the data logger?
No Brian - only one copy of WD is accessing it … the old version works fine and can download data - the new one has this problem
it is strange that it is working OK here every time
but for you, the data logger is not sending back what is expected
(there should be a 6 in that raw data (6 means OK response)
what I could do is add in some more debug code
Thanks for the efforts - do you think it may help to display the port number it’s trying to access? FYI mine is 22222 which I think is default?
the port number is not the problem…otherwise you would not get any data …
I have added in more raw debug info, to the latest update, you have ticked, log the raw data, under setup, advanced/misc
Thanks Brian -
This is what the file has in it
final_data[0]:=196;
final_data[1]:=0;
final_data[2]:=240;
final_data[3]:=1;
final_data[4]:=108;
final_data[5]:=119;
final_data[6]:=237;
final_data[7]:=2;
final_data[8]:=46;
final_data[9]:=149;
final_data[10]:=2;
final_data[11]:=0;
final_data[12]:=2;
final_data[13]:=28;
final_data[14]:=0;
final_data[15]:=255;
final_data[16]:=255;
final_data[17]:=255;
final_data[18]:=255;
final_data[19]:=255;
final_data[20]:=255;
final_data[21]:=255;
final_data[22]:=255;
final_data[23]:=255;
final_data[24]:=255;
final_data[25]:=255;
final_data[26]:=255;
final_data[27]:=255;
final_data[28]:=255;
final_data[29]:=255;
final_data[30]:=68;
final_data[31]:=255;
final_data[32]:=255;
final_data[33]:=255;
final_data[34]:=255;
final_data[35]:=255;
final_data[36]:=255;
final_data[37]:=255;
final_data[38]:=0;
final_data[39]:=0;
final_data[40]:=13;
final_data[41]:=155;
final_data[42]:=0;
final_data[43]:=0;
final_data[44]:=0;
final_data[45]:=255;
final_data[46]:=255;
final_data[47]:=0;
final_data[48]:=0;
final_data[49]:=0;
final_data[50]:=0;
final_data[51]:=187;
final_data[52]:=19;
final_data[53]:=65;
final_data[54]:=0;
final_data[55]:=116;
final_data[56]:=0;
final_data[57]:=131;
final_data[58]:=12;
final_data[59]:=255;
final_data[60]:=255;
final_data[61]:=255;
final_data[62]:=255;
final_data[63]:=255;
final_data[64]:=255;
final_data[65]:=255;
final_data[66]:=0;
final_data[67]:=0;
final_data[68]:=0;
final_data[69]:=0;
final_data[70]:=0;
final_data[71]:=0;
final_data[72]:=0;
final_data[73]:=0;
final_data[74]:=0;
final_data[75]:=0;
final_data[76]:=0;
final_data[77]:=0;
final_data[78]:=0;
final_data[79]:=0;
final_data[80]:=0;
final_data[81]:=0;
final_data[82]:=0;
final_data[83]:=0;
final_data[84]:=7;
final_data[85]:=3;
final_data[86]:=6;
final_data[87]:=12;
final_data[88]:=13;
final_data[89]:=2;
final_data[90]:=13;
final_data[91]:=7;
final_data[92]:=10;
final_data[93]:=13;
final_data[94]:=78;
final_data[95]:=7;
final_data[96]:=7;
final_data[97]:=76;
final_data[98]:=79;
final_data[99]:=79;
looking for what shows under view, debug info, after the history data start up
Sorry - here it is:
Loaded units
logfile count 0
sending DMPAFT
176
279
379
40
50
6134
72
8100
9119
10238
112
1250
13132
142
151
163
1715
180
19255
20255
21255
22255
23255
24255
25255
26255
27255
28255
29255
30255
31255
32255
33255
3475
35255
36255
37255
38255
39255
40255
41255
420
430
440
4533
460
470
480
49255
50255
510
520
530
540
55187
5619
5777
580
59116
600
61131
6212
63255
64255
65255
66255
67255
68255
69255
700
710
720
730
740
750
760
770
780
790
800
810
820
830
840
850
860
870
887
893
906
Davis VP Retrieving data from: day 8 month 10 year 2015
Retrieving data from: hour 18 minute 6
19
211
32
413
57
610
713
0 9 11 2 13 7 10 13
sending DMPAFT
1230
242
376
479
579
60
70
8134
92
10100
11119
12238
132
1450
15132
162
171
183
1915
200
21255
22255
23255
24255
25255
26255
27255
28255
29255
30255
31255
32255
33255
34255
35255
3675
37255
38255
39255
40255
41255
42255
43255
440
450
460
4733
480
490
500
51255
52255
530
540
550
560
57187
5819
5977
600
61116
620
63131
6412
65255
66255
67255
68255
69255
70255
71255
720
730
740
750
760
770
780
790
800
810
820
830
840
850
860
870
880
890
907
913
926
19
211
32
413
57
610
713
0 9 11 2 13 7 10 13
sending DMPAFT
1230
242
376
479
579
60
70
8134
92
10100
11119
12238
132
1450
15132
162
171
183
1941
200
21255
22255
23255
24255
25255
26255
27255
28255
29255
30255
31255
32255
33255
34255
35255
3675
37255
38255
39255
40255
41255
42255
43255
440
450
460
4733
480
490
500
51255
52255
530
540
550
560
57187
5819
5977
600
61116
620
63131
6412
65255
66255
67255
68255
69255
70255
71255
720
730
740
750
760
770
780
790
800
810
820
830
840
850
860
870
880
890
907
913
926
19
211
32
413
57
610
713
0 9 11 2 13 7 10 13
sending DMPAFT
163
27
376
479
579
60
70
8134
92
10100
11119
12238
132
1450
15132
162
171
183
1946
200
21255
22255
23255
24255
25255
26255
27255
28255
29255
30255
31255
32255
33255
34255
35255
3675
37255
38255
39255
40255
41255
42255
43255
440
450
460
4733
480
490
500
51255
52255
530
540
550
560
57187
5819
5977
600
61116
620
63131
6412
65255
66255
67255
68255
69255
70255
71255
720
730
740
750
760
770
780
790
800
810
820
830
840
850
860
870
880
890
907
913
926
19
211
32
413
57
610
713
0 9 11 2 13 7 10 13
sending DMPAFT
1219
234
376
479
579
60
70
8134
92
10100
11119
12238
132
1450
15132
162
170
183
1946
200
21255
22255
23255
24255
25255
26255
27255
28255
29255
30255
31255
32255
33255
34255
35255
3675
37255
38255
39255
40255
41255
42255
43255
440
450
460
4733
480
490
500
51255
52255
530
540
550
560
57187
5819
5977
600
61116
620
63131
6412
65255
66255
67255
68255
69255
70255
71255
720
730
740
750
760
770
780
790
800
810
820
830
840
850
860
870
880
890
907
913
926
19
211
32
413
57
610
713
0 9 11 2 13 7 10 13
sending DMPAFT
153
2223
376
479
579
60
70
80
910
1013
116
16
21
30
41
50
669
7133
Sending OK…
810
913
106
116
121
130
141
150
1669
17133
1810
1913
206
216
221
230
241
250
2669
27133
2810
2913
306
316
321
330
341
350
3669
37133
3810
3913
400
logfile count 0
416
4224
43*6
logfile count 0
logfile count 0
logfile count 0
logfile count 0
logfile count 0
logfile count 0
logfile count 0
logfile count 0
Aborted
vp data read in 1
logfile count 3
logfile count 3
VP reception #1 16888 #2 70 = 100
logfile count 5
logfile count 5
