Log files
Convert .log files to .data files does not work on latest version…
there has been no change to the code
and I have tested here and it works OK
It does not work for me. What I have to do? Please give me some advice. Thanks.
I;m sure you know that the logfiles are not .log but have a .txt file extension, as you can see your screen grab, and they convert to data files with a .inf file extension not .data .
On the screen grab, if you want to convert a logfile (.txt) to a datafile (.inf), you just select the correct .txt file from that list and select convert, and it will do the job in seconds.
If you want to convert a datafile (.inf) to a logfile (.txt), you need to tick the first tick box option where it says 'I want to convert a data (graph) file (.inf) file to a log file instead … and the list of files will change to the .inf extension, and then again just select the file you want to convert, and select Convert
Hope that helps
TrevP
@CaptKirk
if you could .zip and email me your 52017lg.txt file, I will test here
The problem was because I did not switch the “Log file in US” into “Log file in metric”. My apologies and thanks. #-o
