Log file for Air quality readings
Brian can we please have a log file containing the actual AQ readings sent to WD, not the index values but the raw Air Quality readings? I would like to graph these values but currently there are no AQ logfiles only AQI data files.
you can set WD to create a custom logfile using custom tags
Brian I already use custom log file but I have a problem in that they all have to have the same options. I need each one to have separate options such as append/overwrite and timings such as every minute/5 mins /10 mins etc. The ones I currently use all have overwrite but the new one for AQ values needs append and I cannot do that within the current design. Is there some way this can be accomplished? Changing them all to append means re-writing all the code which uses the current files
so you could re write your code?
(instead of me having to spend hours on adding something that very few people would need or appreaciate?)
OK Brian, I just thought originally that as there are .inf files I could create a log file from them using the convert function and it seems to work but I am unable to find any log file created from it, so I thought since there were .inf files creating .log files might be simple which is why I asked originally. I am unable to make sense of the .inf file contents otherwise I would use that instead. If this is not possible I will have to look for a solution outside of WD which is not really what I want.
